- A/C Not working :(
- HELP ASAP!
- Steering Problems
- Injection pump start solenoid wiring
- 12V heating and air question
- cleaning out the guts of an NV4500
- NV4500 Stuck in 5th
- how do i pull the 5speed leather boot off?
- EGT Temp?
- Fuel mileage
- white smoke
- valve springs...
- questions on parts
- diesel shop to set 12v pump timing, near mississippi.
- 1997 12v 5speed perfect setup
- Curious?
- what to buy next?
- How To Adjust The Timing On My 12v
- 12V Power
- doing kdp tab, need advice
- how much can i do without hurting stock trans
- hx35/40 hybrid and no difference!
- First diesel newb with lots of questions
- leaky injector
- new turbo and more upgrades.
- how do i gut the afc housing?
- getting the compressor wheel off
- shift boots
- IC surface temp?
- what does the star wheel affect?
- advance timming with out the dial indicator method
- 95 4x4 207,000 miles?
- budget turbo upgrade?
- gov spring question
- 60lb valve springs
- nv4500 tranny fluid
- frankenstien my 12v
- things i have done and the problems im having
- put the new rack plug in tonite
- Killer dowel pin
- its the gauge, not the turbo...Help please
- louder turbo whistle
- Speedometer problems
- im having turbo problems
- Over flow valve
- Transmisson Trouble
- balancing my turbo?
- How does the fuel plate work
- boost leak?
- Turbo problem??
- what to do next
- Turning my exhaust manifold 180 degree
- 3rd guage
- what is a cummins m11 H55 turbo?
- holstet vgt
- max boost 27ish?
- security system??? wtf??
- Dash Pod?
- Ram Service Pub 81-370-6108
- frankenstien my motors turbo
- Electric fan clutch
- head removal
- hx35/40 hybrid
- cummins on a budget
- 47rh?
- VACUUM PUMP 911
- water issue
- I'm wanting to convert my 95 with a 47rh to a nv4500
- timeing effect shift point?
- hx 55 urgent!!
- dampener
- throwout fork
- injector lines
- Transmission cooling and the heat exchanger
- somebody help
- grinding the fuel plate
- painting under the hood
- paint or polish?
- brakes???????
- Exhaust Brake ?
- more power
- boost psi?
- waste-gate cut-away
- best turbo?
- water in fuel lt after filter change
- Steering Box?
- sluggish off line
- Water/Methanol Injection
- tc?
- Injection Pumps
- fuel leak
- intake gaskets
- rattling noise
- wat are the temps.
- a/c only on the floor
- gota wack my starter
- optima red top
- kdp
- whistle
- lock up vs suncoast TC
- Torque Convertor Lock Up
- allison in dodge?
- i have a goal and need help!
- Turn up pump?
- vin D or 6
- torque converter lock switch
- fuel filters
- negative camber
- is my intake as good as AEM?
- injector leakin on my 12 valve
- fuel plate and throttle
- Motors Almost Complete Rebuild.
- tuning the pump
- new exhaust
- Overdrive Switch
- fuel guage problem
- Flippin death wobble!!
- typical dodge rust!
- 12v timing sweet spot
- Cooler
- towin hooks
- trans temp gauge
- ordered my 4k gov. kit
- Axle Wrap issue's
- INTERCOOLER PIPES
- 12v Injection Pump Timing
- Engine Oil
- Transmission shifting too much?
- Wastegate Fully Closed
- Temp
- 98 california 12 valve help
- ball joints and tie rods
- TCC Mystery Switch
- looking for place to get aftermarket camshaft?
- 12V cold start stall?
- how much HP
- how to adjust idel
- fuel lines.
- all 4 gauges?
- Clutch install and removal HOW to?
- my first 12 valve
- stalls in reverse
- Help my truck is about to self destruct
- 215 pump injectors
- what size fuel tank?
- no start when hot maybe ???
- Mag Hytech Tranni Pan
- Short Shift Kit Question
- crap! what should i do
- Cab Light Install?
- tranny
- kick down cable
- hmm
- rpms and fuel plates
- guttin the muffler
- change the gears?
- usin two stroke oil
- throttle stick
- trany problem
- ac is killing me
- turbo ring
- fuel plate
- Filter Sucked In?
- trans temp probe location
- hard starting after plate install
- sled pull/lock up?
- TQ lock up question
- slippde timing?
- boost elbow???
- cruise control issue
- break off screw???
- how to get better mpg?
- high idle
- 47re to NV5600 conversion
- air truck horns
- need more power
- de-lip, open piston bowl?
- Reverse light hookup 47RH
- BEST CHOICE EXHAUST
- Governor
- 45 psi
- takin out seats
- Single Stack Tips and install pics
- air ?s
- Idle
- Ball Joints?
- isspro gauge short
- Oil Pressure Sender 98 12 valve
- beefin up the tranni
- Fuel plate question
- Tranny Question..
- 24 valve on 12 valve
- dyno results
- Electrical Problems on 98 12V
- Wastegate help ....
- My fuel problem
- the low down on my stock fuel plate
- lift pump
- EGT gauge
- Where do I hook in the trans gauge ???
- white smoke/no power
- Options
- Cruise control
- 3000 gov kit.
- misfortune
- throttle valve cable
- Removing Starter??
- in or out
- HTB2 or B1 bomber?
- Downpipe Question
- 2002 VB in a 1998 12v causes TRANS TEMP light...
- spewing fuel
- need help
- timein at 16?
- what year has the best 12v for engine swap
- no power at start
- tranny temp???
- ATF as fuel additive ??
- 1997 12 valve engine wiring harness needed
- Installing Gauges
- wondering what i should do
- i've got the bug
- Nitrous
- Afc arm
- SMOKE
- odometer question
- egt tune
- Fuel Plate and Towing
- tire toe in
- High EGTs at idle
- auto trans shifting
- ENGINE DIES
- Need ADVICE on transmission .
- No power to transmission
- Weirdness
- this cant be right! help!
- 12v low to mid rpm stumble
- 12v cummins whats wrong?
- marine injecter
- Mpg?
- brakes
- help
- need some advice
- pistons
- O/D Wiring Diagrams For 47rh
- Four wheel drive actuator
- Head Bolts
- Question about turbo
- valve guide seal? update on this? Keep them down?
- Guages quit workin
