PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : 1 2 3 4 5 [6]
  1. new tranny with problems, GRRRRR!!
  2. injector torque specs
  3. Don't get mad! Where should i start?
  4. Turning up my timing tuesday what would you bump it up?
  5. Can any one help me KDP came out and need to fix how can I do this cheap?
  6. crossover tubes?
  7. 12 Valve Fuel Economy
  8. some more quesions
  9. gov springs
  10. What To Buy ?
  11. How to get oil out of antifreeze
  12. 2 QUESTIONS
  13. 96 Wiring Schematic
  14. 95 46RE Won't Shift
  15. Seat Belt Won't Unlock????? HELP!!!!!
  16. Somethings Tapping
  17. Totaled Truck..Speculation
  18. Something Gave
  19. Oil Pressure
  20. KDP repair kit
  21. How Much To Fix KDP?
  22. Dually To Single Wheel Conversion
  23. Blue Smoke
  24. All New Parts For The Front End...
  25. Water Temp Sensor
  26. Lift Pump Quitin, Any Economical Home Builds
  27. 0 plate and NO SMOKE
  28. Trans Shifts Real Hard...
  29. Temp Gauge?
  30. Smoke Button Help...(attn. cumminsdieselboy)
  31. 47RE 12v TV Cable Adjustment - 12 Valve Dodge Cummins Transmission
  32. No 4WD
  33. Don't Want GM Parts
  34. Blow By Every Now And Again Blue Smoke
  35. 98 12V Steering Problem
  36. White Smoke?
  37. A Few Auto Trans Questions
  38. Good Buy?
  39. New Fuel Filter Setup
  40. I NEED SOME HELP
  41. Looking For Some Stick Ideas
  42. 12 Valve Dog Off The Line
  43. What Torque Converters.....
  44. Oil Line?
  45. NV 4500 Stuck In 5th
  46. Grrrrr... 3rd Head Gasket In 6 Months!
  47. My Parts So Far........
  48. Trading A Ford For A Dodge.... What To Look For
  49. Where Is The Catalyst Sticker On 98 12 Valve?
  50. Squeaking Noise From Speed Bump?
  51. PS Pump Bushing
  52. emission requirments for texas? movin there
  53. What Does The Shutdown Solenoid Shut Off ?
  54. New Fuel Plate And Which One?
  55. 12 Valve Shuttering
  56. Tranny Slipping
  57. Idle Problem
  58. Fuel Tank On The Dodge
  59. How To Make A P-Pump Like This?
  60. Will 37s Fit?
  61. TPS / Throttle Positioning Sensor - Adjustment
  62. Fuel Shut Off Problem
  63. Turbo Silencer Ring
  64. Buying A Cummins I Can't Look At..
  65. Timing cover torque specs???
  66. 215 injectors
  67. Drained Battery wrecks CD Player?!?
  68. I need a replacement transmission
  69. 12 Valve Engine Problem
  70. More Delivery Valve Questions
  71. #0 plate
  72. Lost 5th gear...
  73. Bad Steering Issue
  74. T-Case Issue?????????????
  75. What's Up With My Steering?
  76. Oil Pressure
  77. Would This IHI RHB7 Be An Upgrade On My 6BT?
  78. 215 HP P-7100 Question
  79. 60 lb Valve Springs....
  80. 1992 D350 Won't Start
  81. I Think I Just Bought Another Rig...
  82. Intermittent Problem?
  83. 12V Input
  84. Delivery Valve Questions
  85. 12v Here To Stay
  86. Dually Conversion
  87. P7100 Pump Cutaway Photos
  88. 1994 Injection Pump
  89. Vibrations From The Front End
  90. 4x4 Broke
  91. Need A TPS
  92. Headlights And Blower Motor
  93. Pyro Problem
  94. No Smoke?
  95. Loss Of Power
  96. Speedometer Quit
  97. 3rd Gear Let Go Today
  98. Thermostat?
  99. Trucks Dead...Again!!!
  100. 8.3 Pump On A 5.9
  101. Fuel Pressure
  102. Truck Having A Problem
  103. Major Trans Problem….
  104. NV4500 4x2 To 4x4
  105. NV 4500 Clutch Install
  106. Shifter From A 96 To 94
  107. Pinion Seal
  108. NV4500 To NV5600
  109. Bad Vibrations
  110. Alternator Wiring
  111. 12v Turbo Maxing At 17PSI
  112. 12v Blue Smoke
  113. Speedometer Correction
  114. Thinking About Selling The Dodge
  115. Smoke
  116. Speedometer Quit
  117. 4.10 To 3.54 ???
  118. More Trouble With My 97
  119. Starting
  120. Lift Pump Tick
  121. Not Sure, But Could Be A Problem!
  122. Axle Bolts
  123. Setting Timing From Scratch.
  124. 12v Fuel Pressure Test Fittings List
  125. Gear Ratio Questions
  126. Timing
  127. Trans Overflow?
  128. Transmission
  129. Whats Wrong With This Truck????
  130. Losing Coolant
  131. Few Auto Questions.
  132. 1997 CTD Problem
  133. 91 & 94 4x4 Cummins
  134. 1994 Cummins Farm Truck That Has A Few Problems...Please Help
  135. Fitting 2002 Aluminum Rims On A 1996 Truck
  136. 1994-1996 FLASHING OBDII Codes
  137. 1994-1998 12V Idle Adjustment
  138. 1994-98 Ram Diesel Fuel Shutdown Solenoid Adjustment
  139. Steering Gears And Shafts
  140. Coolant Temp Sensor Location
  141. 47RE Trans /Converter Question
  142. Surging Around 1200rpm
  143. Fuel Filter Replacement
  144. Auto Trans Question
  145. 3rd Gen Track Bar
  146. Im Bummed
  147. 97 Automatic, Converter Lock-Up Switch
  148. NV4500 Rebuild Questions
  149. What Do You Guys Think About This Truck?
  150. I Think I Know Whats Wrong, Help Me Confirm It Please
  151. Part Number
  152. Best Place To Get Transmission Parts For NV4500?
  153. Oil Leak Help
  154. 12 Valve Cummins Pic
  155. Injector Pump Needs Rebuilding
  156. AC/Vent Fan Doesn't Work
  157. NV4500 Problem
  158. Hey Everyone
  159. When To Advance Timing
  160. Axle Seal
  161. How Hot Is Too Hot
  162. Tranny/Transfer Case Questions
  163. Shuddering Noise From Tranny?
  164. Gettin Time For A Tranny
  165. Rear Main Seal
  166. Common Fuel Plate Profiles
  167. Just Installed #10 Plate. What A Waste...
  168. I Want To Ditch My Cat But Not My Muffler. Bad Idea???
  169. Good Source for quality Valve Cover Gaskets
  170. EGR valve removal '97 12 valve
  171. 4.5 GSK
  172. 60lb Valve Springs
  173. i got problems
  174. NV4500 Troubles
  175. 1st Gen.. Tranny
  176. 97 Wont Go Into O/D
  177. cam gear and power steering pump gear
  178. 12v oil amount
  179. pump leak
  180. Cab and chassis 2x4
  181. Differences between 94 and 96?
  182. low, lopey idle
  183. 95' 3/4 to 1 ton
  184. 12 Valve Sensor & Fuel Component Diagram
  185. Injector and DV advice needed
  186. headliner removal
  187. WOT stop adjustment
  188. transmission how much?
  189. P7100 Fuel Plate Profiles
  190. UGH!
  191. 1997 12 valve problem please help
  192. what to do,i have air in clutch system?
  193. Wastegate
  194. 12 Valve Head
  195. Oil Pressure Sender
  196. Helpful Links
  197. overhead temp/compass
  198. 12V fuel pressure?
  199. Drop in milage, where to look?
  200. 47rh T/C
  201. Hi
