tappet/push rod cover gasket
Old Oct 25, 2013 | 02:53 PM
brandon1481's Avatar
Question tappet/push rod cover gasket
hey guys i have a bad oil leak coming from the tappet cover. i need to get it done before it gets to cold outside. i have an idea how to do it. i know you take the ip off to reach it. but i heard you have to retime it. im not sure how to do that and not sure if i need special tools. i know that the truck has stock timing. can anyone help me with this please?
Old Oct 25, 2013 | 06:00 PM
Diesel Phreak's Avatar
Theres a timing pin right the under the pump in the front housing. Use this to get the engine at TDC. Then there is a timing pin on the side of the injection pump that will keep it in time. Then take her off and as long as nothing turned you'll be in time when you put it back together.
Old Oct 25, 2013 | 06:37 PM
so i should be good since the timing hasnt been messed with?
Old Oct 25, 2013 | 06:40 PM
Even if the timing had been messed with all your doing is turning the engine to TDC with the first pin and at that point the pump is timed to the engine no matter where the pump is set too.
Old Oct 25, 2013 | 10:16 PM
4x4manonbroke's Avatar
Make sure you ensure that the grear inner taper and the shaft taper are dry ... I ran the nut down till it was tight , and then did the "snap" ... like jammed the gear on right quick with my 1/2" ratchet .... till it was tight...
the first time it slipped and this was a great suggestion by someone who has done this so manny times he could do it blindfolded... Good luck and keep us posted ....
Old Oct 25, 2013 | 10:34 PM
real quick before i get into it. whats TDC?
Old Oct 25, 2013 | 11:01 PM
Top Dead Center... when #1 is at the top of its stoke.... the highest up in the cylinder it can possibly go ... before it goes back down ... if you can find some retaining compound - its llike dychem blueing like what a machinst uses ... it will go on the clean taper of the pump and the inner taper of the gear and keep the two surfaces from slipping ... oif just carefully use a 1/2" impact gun .... just dont over due it or you will be screwed....
quiksilver1j
Jul 30, 2015 12:41 PM
carid
Diesel Bombers Sponsors
Jul 16, 2015 05:11 AM
scrnnmssuck
For Sale
Mar 20, 2015 11:55 AM
woodsman27
Dec 9, 2014 09:55 AM
woodsman27
Oct 26, 2014 02:13 AM
