NV4500 gear oil
Old Nov 2, 2013 | 01:23 AM
sweetv8s10's Avatar
Default NV4500 gear oil
I was needing to add a little gear oil to my nv4500 and I was wondering if royal purple will work and can I add it to whats already in it? Also what weight oil do I have to use?
Old Nov 2, 2013 | 03:13 PM
4x4manonbroke's Avatar
not sure on the weight but know its good stuff .. run it in both my trucks ... 7.3IDI and Cummins 12V
Old Nov 2, 2013 | 04:16 PM
sweetv8s10's Avatar
I think it calls for 75/85 but if I get a weight close to that I was wondering if It would be ok?
Old Nov 2, 2013 | 04:18 PM
mysterync's Avatar
Syncromesh type fluid ONLY. DO NOT use a regular gear oil.
Sent from my SCH-I605 using Tapatalk 2
Old Nov 2, 2013 | 06:15 PM
Good to know ... and yes Royal purple makes a Syncromesh fluid..... and i have used it in a Neon ... shifts awesome
Old Nov 2, 2013 | 06:37 PM
sweetv8s10's Avatar
Yes it has to be for GL4 or GL5 but what about the difference in weights? Can I just get some close to the same weight and use it?
Old Nov 3, 2013 | 09:12 AM
mysterync's Avatar
No, gl4 or gl5 are not safe in these transmission. Syncromesh is a mtl fluid.
And no you can't compare weights and use another oil. This is a white paper on the subject.
http://www.bobistheoilguy.com/forums...1231182&page=1
Old Nov 3, 2013 | 11:11 AM
Yeah dont subsitute anything else ... you will kill the transmission if you do .... and yeah we know syncromesh is not cheep..... but its a must....
Old Nov 3, 2013 | 02:24 PM
sweetv8s10's Avatar
Yes gl4 or gl5 will work because that's exactly what it calls for from Chrysler I know because I checked.
Old Nov 3, 2013 | 04:07 PM
mysterync's Avatar
No it doesn't.
I can give you the part number in another screenshot. The part number correlates to pennzoil and castoroil syncromesh fluids. You can put in if you want but it wont shift well. No where in any manual will you find a gl4 or gl5 recommended for a nv4500 or nv5600.
Originally Posted by mysterync
No it doesn't.
I should also clarify (even though it was covered in the link above) that the syncromesh fluids are gl4 fluids yet all gl4 fluids do not address specific syncronizer needs. A gl4 and a syncromesh mtl are not made equal by the gl4 spec. The article covers the subject more in depth but in basic terms the gl4 is the additive package as it relates to gear wear and other additive packages.
