1996 dodge 12 valve grinding from my nv4500 transmission
Old Nov 5, 2013 | 11:27 PM
Dchames93's Avatar
Default 1996 dodge 12 valve grinding from my nv4500 transmission
I have a 1996 dodge 2500 12 valve cummins with a nv4500 5 spd. My issue is I have a grinding noise when I up shift in 2,3,4,5 gear but its intermittent but not when I down shift, it only happens in 2wd, 4wd it doesn't make a sound, I have drained the fluid in my transmission to check for any obvious damage or shavings aswell as drained the oil in the t-case but nothing, this just started a couple days ago but I did just put a new clutch in a week an a half ago, any connection? Or could it be my transfer case? I'm confused, I'm a heavy duty mechanic but this ones got me beat at the moment
Old Nov 6, 2013 | 11:19 AM
ArizonaRedneck's Avatar
Dodge Truck and Cummins Turbo Diesel Forum - Diesel Bombers Welcome to Diesel Bombers and check here to see if you can find the help your looking for
Old Nov 10, 2013 | 10:13 PM
six speed's Avatar
could it be that your hydralic assembly is weak and not getting the new clutch disengaged like it should?
Old Nov 10, 2013 | 10:56 PM
4x4manonbroke's Avatar
YUP, Sounds like ur clutch is hanging up a bit ... and yes I would check your throw on the slave cylinder ... bet thats ur issue ... Good call by six speed
Old Nov 12, 2013 | 06:52 PM
tiremann9669's Avatar
What did you put in it for fluid ?
hoeky22
For Sale
Mar 15, 2015 08:35 PM
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Tucker126
Jan 2, 2015 08:09 AM
W350-4x4
Nov 12, 2014 09:35 AM
jac60
Oct 28, 2014 03:29 PM
