97 cummins fueling issue???
got a 97 12 valve with a nv4500, driving down the road and noticed it seemed to start to lose power 5th.. 1st 2nd and 3rd it runs awesome, when the turbo lights it takes off. when you shift to 4th everythings good until it reaches 2000 rpm then it acts like its defueling or governing out ( clutch isn't slippin and not losing boost when it acts up) shift to 5th and its just powerless after 1500.. you can dog it out and everything works correctly until it hits 2000 again..i replaced the air filter and then the fuel filter neither helped. fuel filter was nasty looked like a used oil filter..anyone had this problem or know how to fix it, i would much appreciate it. and no i don't have a fuel pressure gauge so Idk what my pressure is :/ and if it matters i can get around 40 of boost until 4,5 and then its 30 maxed.. NEED HELP thanks
yes stock injectors and stock lift pump. and i have a fuel pressure gauge ordered
and i noticed today in the daylight when its cutin out its smokin a blue/white color
Last edited by CumminsPower97; Jul 29, 2013 at 01:54 PM. Reason: Automerged Doublepost
JoeyMiR
9
Feb 3, 2018 10:05 PM
Nov 4, 2014 08:10 AM
Oct 28, 2014 08:10 AM
