Help tranny is leaking!!!
Old Sep 17, 2013 | 10:42 PM
Tanner Green's Avatar
Default Help tranny is leaking!!!
I have a 97 12 valve cummins with 280xxx
Ext cab, long bed, auto tranny
When I bough the truck the guy said it had a rebuilt tranny, now I'm leaking tranny fluid, it keeps shifting down, revs up to high rpms and won't shift, but I'm losing fluid somewhere, I looked on the back of the tranny it has a few different numbers and don't know what they are for? Help anyone? Don't really drive it hard never had leaked untill a few days ago. there's 09104, C-17457 4, then there's circle plate with a model number 241 DLD, I'm confused someone please help me
Old Sep 18, 2013 | 11:38 PM
RedChevy44's Avatar
241 DLD is your transfercase. It bolts to the transmission using 6 studs with nuts on them, in a circular pattern. Is your transmission leaking or is it your transfercase, or is it between them?
Old Sep 19, 2013 | 08:47 AM
On the front of the tranny there's 2 metal lines, they run from the front to the back of the moter and the run right in front of the tranny pan and there's tranny fluid dripping off them, my whole exhaust on my passenger side is covered none of the seals are leaking unless there's something on top that I can't see? Am I missing something?
Old Sep 19, 2013 | 09:47 PM
4x4manonbroke's Avatar
there should be 2 nylon/plastic clips that hold those lines in place .... there is a o-ring behind that ... most likley they are deteriorated or just plane out BAD....
Old Sep 20, 2013 | 08:37 AM
Ok what are those lines? Do they have tranny fuild running threw them? Are they just called return lines?
InheritedDiesel
Jun 3, 2015 09:39 PM
wilki
Feb 12, 2015 09:04 AM
Ol' RED!
Dec 11, 2014 10:00 AM
Stox5225
Nov 18, 2014 01:04 PM
Trevlar11
Nov 16, 2014 01:59 PM
