GETTING HOT!!
Old Sep 9, 2013 | 06:42 AM
GARYKENYON's Avatar
Default GETTING HOT!!
Hey guys, I need a bit of advice. Weekend before last I used my truck and a 20' gooseneck trailer to help a friend move from GA to NC. The gross vehicle weight was just over 21,000 pounds. Now, keep in mind that it is August in the south I expected temps to get a little high, but my water temp was riding at between 220 and 230 the whole way and was approaching 245-250 pulling the hlls. My EGTs peaked at about 950 but stayed in the 600-800 range for the majority of the trip. I'm runing a 12v Cummins out of a 1992 El Dorado bus (40 passenger bus for American Airlines). Although it is a '92 it has the P7100 inline fuel pump. Is it just me or do these numbers seem a bit high? Some other information that might help: I am running 4 10" electric fans with a shroud, The motor is turboed and intercooled using the turbo and intercooler that was in the bus. I can't think of anything else y'all might want to know. Thanks in advance, Kenyon.
Old Sep 9, 2013 | 07:20 AM
Tyler Smoot's Avatar
your EGT's are in the clear and i would say relatively low for a 21k pound load. Very good EGTS. as for your coolant temp yes that is hot, esp with 4 10in fans runnings. check for air pockets, you may be running water only rather than a antifreeze solution which also helps to cool, most likely your thermostat is stuck open which never allows coolant to cool down since its always flowing. IF it is stuck open then it will take your truck longer to warm up.
Old Sep 9, 2013 | 01:49 PM
GARYKENYON's Avatar
That makes sense. I'll give it a shot. Unfortunately it will be a while before I know whether or not it worked because I work less than 3 miles from my house so it barely even gets warmed up by the time I get there (Another sign that maybe the thermostat is staying open). Thanks for the advice. I just thought it was weird that it was getting so hot. Typically 12v guys are complaining that their power plants never seem to warm up. Leave it to me to be different!
Old Sep 9, 2013 | 09:20 PM
sweetv8s10's Avatar
Is your pyrometer before or after the turbo?
Old Sep 10, 2013 | 03:46 AM
GARYKENYON's Avatar
My pyrometer is about 2 1/2" down from the exhaust side of the turbo.
Old Sep 10, 2013 | 02:30 PM
sweetv8s10's Avatar
So that means your exhaust temps were peaked closer to 1250 or 1300 which is pretty warm because you should add 200 to 300 degrees if your pyro is after the turbo.
Old Sep 10, 2013 | 04:39 PM
GARYKENYON's Avatar
So, I guess the next question is: How do I cool this pig off? 21,000 pounds isn't too much for a 12v is it? It IS stock for the most part as I am not too sure what to do to it to get more power, but on the flip side of that, doesn't more power usually mean more fuel, which in turn means more heat? The intercooler, radiator and turbo were all taken directly out of the bus and installed in my truck so I would assume they are sufficient, right? Would Tyler Smoot's thoughts on a stuck thermostat cause sky-rocketing EGTs? Like I said before, I am learning as I go, but I don't wanna learn the hard way. I'd rather learn from your mistakes than have to make my own. Thanks for the advice!
Old Sep 10, 2013 | 10:47 PM
4x4manonbroke's Avatar
I think you might have some restriction in the radiator or the cac( if in front) could cause some air to be blocked out a bit...
work for a bus company ... love these little busses
Old Sep 11, 2013 | 07:21 AM
GARYKENYON's Avatar
Yeah, my firsyt thought was that maybe some mud or something had caked the intercooler and was preventing air from even getting to the radiator, but when I stopped and checked it out everything appeared to be clear. I even looked between the intercooler and radiator to see if maybe leaves and debris had somehow built up in there but that too was clear. Also, I failed to mention in previous posts that when we would take an exit the water temp would almost immediately drop down to 210 and the EGT would drop down to 500. I will get after it with the hose and make sure all of the fins on both the intercooler and the radiator are clear, thanks for the advice.
Old Sep 11, 2013 | 11:33 AM
sweetv8s10's Avatar
I had a 92 and it would run warm on long pulls but never could figure out why so I got rid of it hopefully you can figure out the problem.
