WHICH GOVERNOR SPRING SET WORKS BEST
Old Nov 3, 2013 | 10:09 AM
monstercat's Avatar
Default WHICH GOVERNOR SPRING SET WORKS BEST
I have a 98 cummins 12 valve. and I'm going to install a 3K governor spring set in also install 60# intake valve springs, I already have 60# exhaust springs. which brand would you recomend I use.
Old Nov 3, 2013 | 11:11 AM
4x4manonbroke's Avatar
they all should qualify .... unless you have a specific brand in mind
Old Nov 3, 2013 | 05:09 PM
JBearSVT's Avatar
I went with the Bosch springs. Seemed to be a good idea at the time, and no complaints. If you're only doing the 3K kit, there's no reason to do valve springs. In fact, I have the 4K kit, and I haven't done them. Just because you have a 4K kit doesn't mean it will rev that high, there's more involved with getting it to rev that high than just governor springs. I sure as hell wouldn't bother with valve springs on a 3K kit though, no matter what else you do.
Old Nov 3, 2013 | 05:12 PM
Dustindavisusmc's Avatar
Buy the PAC brake set, the come with 3k and 4k springs, and good destructions
Old Nov 3, 2013 | 05:17 PM
JBearSVT's Avatar
I believe the only difference between 3 and 4K with the PAC kit is the number of springs. If someone can confirm this is the case, I would buy the the 4K kit and leave one spring out. Then when you decide you aimed too low, you can just pop the last one in and have a 4K kit.
Old Nov 3, 2013 | 05:51 PM
It's actually add spring for 3k, and I can confirm it, modified a few pumps
Old Nov 3, 2013 | 07:47 PM
JBearSVT's Avatar
I was pretty sure it was either put one in or leave one out...
Old Nov 3, 2013 | 08:43 PM
turbo2332's Avatar
you leave the little inner spring out for a 3k kit and install all springs for the 4k.
these folks have a good description of it and a picture. good old google
94 98 Dodge Cummins 12 Valve P7100 Injection Pump 3K and 4K Governor Spring Kit | eBay
Old Nov 3, 2013 | 10:36 PM
LOL... i want the part numbers for the Pac kit if you would please ....
and there's a reason for installing heavier springs on those engines planning on seeing 4K for any leingth of time ... its called valve floating .... it will case the valve to bounce off the valve seat and can damage the valve and the cylinder head, cracking the seat or warping a valve .... The heavier VS helps control the valve more precisely, saving you a tone of parts that "possibly could be damaged" .
And its cheep insurance when u decide to slow down with a exhaust break as you will have to have them then no matter what .... usless without
Last edited by 4x4manonbroke; Nov 3, 2013 at 10:36 PM. Reason: Automerged Doublepost
Old Nov 4, 2013 | 08:58 AM
HP10029PACBRAKE
turbo 3223 might be right... with add or pull, but the directions come with... its and easy deal
Last edited by Dustindavisusmc; Nov 4, 2013 at 08:58 AM. Reason: Automerged Doublepost
