1996 regular cab conversion
Old Jul 17, 2013 | 09:35 PM
cummins199's Avatar
Default 1996 regular cab conversion
has anyone converted a regular cab long box 1996 dodge into a extended cab short box? will it work? how much reconverting did you do? would like some real life expierences!
Old Feb 17, 2014 | 08:57 PM
dieselram94's Avatar
Did you ever accomplish this?
Old Feb 20, 2014 | 06:59 AM
sammuel velazquez's Avatar
but i wish i could but mine already canme as a regular cab short box
Old Feb 24, 2014 | 08:22 PM
coors_man_2005's Avatar
I think the wheel base is shorter on the reg cab long bed over the ext cab short bed. I'm thinking this because my c&c truck is the same wheelbase as the ext cab short bed. Would be easier to do like what I did and get an ext cab short bed 1/2 ton and swap all the parts over everything is bolt and go deal that way and you have all the parts you need for a swap right there in your hands. I have a build thread posted here mine is 2001 1/2 ton with 94 12 v set down in it. 1/2 ton motor mounts and trans mount are the same
Old Feb 25, 2014 | 02:33 AM
You're right the wheelbase is different... exactly four inches longer for the extra cab short bed, but frame length is only about 1/8" different. I am going to use my regular cab long bed frame over my 1/2 ton frame because it has no rust where my 1/2 ton frame is crusty especially at the joint where the rear section splices into the front section. I am going to relocate the rear axle back and use a body lift/ relocate body mounts on the frame.
Sent from my USCC-C6721 using Tapatalk
Do you have a link to your build thread?
Last edited by dieselram94; Feb 25, 2014 at 02:33 AM. Reason: Automerged Doublepost
Old Feb 25, 2014 | 07:15 AM
https://www.dieselbombers.com/12-val...ins-build.html
That's cool to know the actual frames are the same just axle relocated.
Old Feb 25, 2014 | 09:52 AM
The frames have a different profile. The overall length is the same. Thanks for the link. I'll check it out...
scubasegt
Jun 9, 2015 12:07 PM
Radioking1777
Jun 8, 2015 10:26 PM
rajdiesel
Mar 14, 2015 07:11 AM
RHIT_Cummins
Dec 16, 2014 10:14 AM
Jthompson_32
Oct 5, 2014 09:51 PM
