auto and manual bellhousing??
Old Nov 30, 2013 | 11:43 PM
White96cummins's Avatar
Default auto and manual bellhousing??
well im about to do my nv4500 swap. but i have a few questions.. will my rear driveline work?? and are the bellhousings different or can i use my auto one with the manual?
Old Dec 1, 2013 | 10:04 AM
olsmokey's Avatar
do you mean the bellhousing adapter?
Old Dec 1, 2013 | 05:14 PM
AMS247's Avatar
The adapter plate that the bell housing bolts to is the same, however you will need to get a new driveline. The 47RE and NV4500 have a large difference in legnth so you will need to get one built at a drive shaft shop or if you have a 3500 you can buy one from a truck that came with a NV4500 as well. All manuals came with a Dana 80 axle, as only the Automatic 3500 came with the same axle, all 2500 Automatics came with a Dana 70. The Dana 70 axle equipped truck's drive shaft is about 1" longer due to the smaller pinion size.
Old Dec 1, 2013 | 05:45 PM
Slim Whitey's Avatar
hm, good to know I'll need to swap rear diffs as well when I do this.
Old Dec 1, 2013 | 10:58 PM
4x4manonbroke's Avatar
no need to swap the diff ... just the drive shaft ... the diff will be just fine
chadcycle 2500
Sep 21, 2015 06:02 AM
PapaDaus
Jul 5, 2015 08:10 AM
Beau_Jacques
Jun 26, 2015 12:17 PM
Jgloveracob
Nov 16, 2014 07:27 AM
Just-Another-Dieselguy
Nov 14, 2014 02:07 PM
