ok guys no lockup at all
Old Nov 18, 2013 | 10:22 PM
Gotta<3a12valve's Avatar
Default ok guys no lockup at all
My buddies 47rh won't lockup even with manual lock switch?
Took pan off changed cylenoids and they engage when u flip switch so why wouldn't it lock tried everything?
Old Nov 18, 2013 | 10:59 PM
Slim Whitey's Avatar
no lockup at all with a manual switch. . .
well, not that I have really any experience with these things, but if everything that should make a part do something works, and you've checked that it all works, and that does not do that something when told to, I'd be looking into that parts integrity.
Basically, I'd be seeing if the tq still has the ability in itself to fully lock.
However, if I were you, I'd wait for a more reliable person than I.
Old Nov 19, 2013 | 05:03 AM
turbo2332's Avatar
trans temp sensor on the line coming out of the trans. it wont shift till its warm and if that sensor is broke it wont shift into OD or lockup ever.
Old Nov 19, 2013 | 09:57 AM
I bypassed that with a 1k resistor ... Ive tried the basics
It goes in o/d
Slim... You may be the only guy in history thats switched from ford to cummins and didn't like it ... Whats wrong with your truck???? Must be a turd to make u want a ford
Last edited by Gotta<3a12valve; Nov 19, 2013 at 09:57 AM. Reason: Automerged Doublepost
Old Nov 19, 2013 | 12:08 PM
My Ford was a bigger basket case when I bought it than my Dodge.
But with the amount of time and effort I put in, I made it into a great truck, and that truck & I went through a fair bit in our travels.
The Dodge will go a long way to beat that.
Anyway, lets keep the discussion on your issue.
Old Nov 19, 2013 | 02:33 PM
4x4manonbroke's Avatar
sounds like either a lock up solenoid or the clutch in torque converter is toast .....
when was the last time you had the transmission service done ?
what are your line pressures ?
have u checked to see if the OD button in dash is not faulty ?
any of these things could be going in ..... if it were me .... find a reputable trans shop and have them diag ur issue's and save u some unnecessary parts and such ... IMHO of course ..
Old Nov 19, 2013 | 10:14 PM
O/d button work s changed fluid & filter maybe its converter although it still drives right
Old Nov 20, 2013 | 03:29 PM
could have junk in VB .... thats what was happening with mine .... not I need to turn up line pressure just a biy more on the upper end ... shifts a bit late and loose ...
Old Nov 20, 2013 | 07:32 PM
how do you turn the line pressure up on these?
Old Nov 20, 2013 | 08:07 PM
turbo2332's Avatar
little bolt on the vb
