chevy 2wd nv4500
Old Aug 17, 2013 | 11:41 PM
adamsmith's Avatar
Default chevy 2wd nv4500
Will a chevy nv4500 mate up to a dodge bell housing?
Old Aug 18, 2013 | 12:15 AM
TheyCallMeCountry's Avatar
Different input shaft. There's a regular version and then there is the HD version that came behind the Cummins and V10s. Earlier model GM had a diff bolt pattern between bell housing and trans case. Inputs are smaller on the GM and you will need a different output shaft. Gm uses a 32 vs. Cummins/v10 29 splines on the dodge. There might be more, but that's all i can come up with. So you'll need a flywheel, clutch, pressure plate, input shaft, bell housing, throw out bearing, pilot bearing and clutch fork. It needs to all be dodge, the only thing GM would be the transmission. But with $$$ anything is possible. Your better off finding a NV4500 out of a wrecked 12 valve or v10 truck that appears to be in good shape. Good luck.
Old Aug 18, 2013 | 09:50 AM
adamsmith's Avatar
Well it is 2wd tranny si output is no issue so for as the rest are u refering to all gm trannies or just the early ones?
Mar 6, 2015 08:10 AM
Dec 3, 2014 09:40 AM
Nov 20, 2014 06:20 PM
Oct 30, 2014 11:50 AM
Oct 16, 2014 07:10 PM
