96 12v Wont start
Old Nov 24, 2013 | 08:30 AM
Cody morris's Avatar
Default 96 12v Wont start
question for you guys, its got me beat Ok so i had just left home shifted into fifth gear mashed the accelerator an it just cut off like you switched it off, bust right off on either got fuel coming to filter and to injection pump and if you crack the line on injector it pumps a little fuel out anyone had an similar problems? Any help will be awesome
Old Nov 24, 2013 | 12:31 PM
Kbnecessary's Avatar
Whats ur fuel pressure u have to have pressure to run not just flow
And does the solenoid pull governor arm up never seen one go out going down road like that all the ones i changed wouldnt turn off but anything can happen
Last edited by Kbnecessary; Nov 24, 2013 at 12:31 PM. Reason: Automerged Doublepost
Old Nov 24, 2013 | 04:04 PM
4x4manonbroke's Avatar
sounds like a fuel silinoid issue to me .. might have a short some where
Old Nov 24, 2013 | 04:36 PM
JBearSVT's Avatar
I've never had my solenoid close going down the road, but I have had it close after it started. Which is a PITA. I'd start there...
Old Nov 24, 2013 | 05:01 PM
tiremann9669's Avatar
Overflow valve, pinch off your return line and if that makes it run it's the ofv
Old Nov 24, 2013 | 05:14 PM
JBearSVT's Avatar
Damn, fought with my shut off valve for so long I forgot about that. We should have a "won't start" checklist stickied here.
Cavnar
Sep 9, 2015 07:18 PM
cjgregory
Mar 31, 2015 01:45 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
