2009 track bar with conversion kit!?!?!?!?!?
Old Oct 13, 2013 | 11:51 PM
new12vguy's Avatar
Default 2009 track bar with conversion kit!?!?!?!?!?
[Hi all i am going to order a conversion bracket so i can put a 3rd gen trackbar on my truck but I have one question i went to my local junk yard and got a track bar off an 09 cummins now is this trackbar the same as 03-07 models? From what I can see it is, but I just want to be absolutely sure. Any and all help is appreciated
Old Oct 14, 2013 | 01:30 AM
H.R.D's Avatar
As far as I know it is the same, they didn't change steering until 2010.
Old Oct 14, 2013 | 01:44 AM
new12vguy's Avatar
Finally! Thankyou
Oh I see your from las cruces! I am in el paso and frequent las cruces as with diesel shops I do not trust any here in el paso. Good to see a fellow member locally!
Old Oct 14, 2013 | 08:27 AM
AMS247's Avatar
03' - 07' used smaller bolts.
07.5' - 11' used a larger sized bolt at both ends.
Shape is the same. Since you found a track bar from an 09', you'll just need to open up the bolt hole on the axle side more, and maybe on the track bar bracket if it was built for the 03' - 07', but nothing that would take more than a couple minutes.
Old Oct 14, 2013 | 09:54 PM
H.R.D's Avatar
Originally Posted by new12vguy
Finally! Thankyou
Sweet my friend. Its good to see more folks close to me as well. I have never dealt with any diesel shops around here, I do all my own work.
Good info.
Old Oct 14, 2013 | 10:05 PM
4x4manonbroke's Avatar
Is his on 4x4 ? or does this apply to 2wd also ?
1ATony
1A Auto Parts
Jul 29, 2015 12:54 PM
CGwill
Jan 26, 2015 02:10 AM
mark402001
Tire, Wheel & Suspension
Jan 18, 2015 03:17 PM
TyCarp
Dec 10, 2014 11:02 AM
motormayhem
Nov 1, 2014 01:24 PM
