97 5.9 dodge 3500
Old Oct 16, 2013 | 01:10 PM
colokerrie's Avatar
Default 97 5.9 dodge 3500
I am using oil . I am not burning it or leaking it .seems to do it more on trips. And I just put new seals on the bottom of the injecters .and ther are still leaking .help cummins fresks
Old Oct 17, 2013 | 03:49 AM
97cummins's Avatar
your using oil, and you put new seals on the bottom of the injectors and their leaking?
I'm not trying to be mean but are you asking two different questions??
Old Oct 17, 2013 | 08:27 PM
4x4manonbroke's Avatar
the seals on the injectors should have been copper O-rings, what other seals did u replace ?
If your engine is using some oil ( like 1 qt every 1K or so ) theres not a real problem, but if your talking about 2 qts every 1K, then you might have a Valve stem issue,
Does it smoke in early mornigns till warmed up ?
What color is the smoke ?
Does it seem to smoke/haze a bit at idle when warm ( at opperating temps) ?
Keep posted and search under truck for leaks, also how much smooke comes out of the oil fill when truck is running cold VS hot ?
Jet A Fuel
For Sale
Aug 16, 2015 04:44 AM
elbedonie
May 19, 2015 10:16 AM
bubbs33003
May 3, 2015 11:31 AM
vaio45
Dec 27, 2014 06:04 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
