750hp build
Old Jul 16, 2013 | 10:04 PM
somkincummins95's Avatar
Up 750hp build
ok i just drove my cousin's 750hp 2003 24v and it is bad a$$!! so i want to make my 95 12v the same but its gonna take some time first of all i want to get straight is the tranny. mine now has a precision triple disk converter transgo shift kit and extra clutches. i know im gonna need a 5 disk converter (im thinking suncoast), billet flexplate, and billet shafts. what am i missing for the tranny? for the motor i know head gasket(what kind? and best place to buy one?) headstuds and valuve springs(what poundage?) i already have the turbo lined up im gonna use my s300 62/65/13 over a s400 probably a 76/90 or something like that. but im not sure how to get that much fuel. any ideas for me? thanks!
Old Jul 26, 2013 | 08:54 AM
smokincummins92's Avatar
Old Jul 27, 2013 | 05:51 PM
yea im actually considering this
Old Jul 27, 2013 | 06:00 PM
turbo2332's Avatar
take the pump off give it to a shop and tell them what you want. you will need a big fuel system you will need 5x16's + for injectors
Old Jul 27, 2013 | 06:26 PM
4x4manonbroke's Avatar
yeah would also get a beefy driveline built to transmit al that power to the ground ... gonna want some cromemoly axles, ..... as far as the HG go with a stock unit from cummins and go with 14MM studs - do this before you even start with mods.... get a good manifold and a 5" exhaust.. I have one on my truck its Diamond eye Straight piped ... sounds awesome .... good luck ... will be keeping my eyes peeled on this one
Old Jul 28, 2013 | 08:43 PM
its gonna be while im just getting some ideas now on what i need so i can start stocking up
Old Jul 29, 2013 | 06:01 AM
NEWBIE 98's Avatar
Old Jul 29, 2013 | 01:13 PM
94 12valve's Avatar
no need for 14mm studs the 12mm will work just fine. while you have the head off get it o ringed, a good set of valve springs, a good vlave jod and mild porting if you can afford it.
The rest is pretty easy just do a good search and you will find the info you need.
bigbadDT
Diesel Engine Conversions
Aug 28, 2017 06:36 AM
redveloce
38
Jan 22, 2017 03:55 PM
DODGEARMYGUY
Feb 8, 2015 07:08 PM
jtwthaxj
Jan 14, 2015 06:52 AM
Oct 15, 2014 12:30 AM
