Marine engine?
Old Jul 31, 2013 | 10:23 PM
firstgen_17's Avatar
Default Marine engine?
I recently took the thermostat out of my truck to replace it. I couldn't find the correct one for it anywhere. I finally put one in out of a Jeep Grand Cherokee but no one needs to know that but I googled the serial number and they are telling me it's a marine engine. The number is 6b5.9-180. I talked to a diesel shop and they don't think it is one. Can anyone tell me for sure if it is a marine engine?
Old Aug 1, 2013 | 08:27 AM
93_Fummins's Avatar
"6b5.9-180" is the series number, not the serial number. It's for 6 cylinder, B-series, 5.9L, 180 hp. Sounds like a standard Dodge late 90's configuration, as the "industrial" ones were generally 190 hp configurations (and a completely different pump cam, from what I've learned) and the "marine" engines were rated much higher and generally had special stuff for hull cooling and whatnot if it was a TRUE marine spec motor.
Does the engine have a information tag rivited to the timing gear housing? That will generally tell you everything you need to know...
As for the thermostat, any B-series one should work....how could you not find a Dodge 12 valve Cummins thermostat? Most parts stores should have it...as well as Dodge and Case/IH dealers...
They make a few preset degree thermostats. According to Pure Diesel Power:
Cummins 180* Thermostat: P/N 3928499
Cummins 190* Thermostat: P/N 3946849
Then you'll need the sealing rings too: P/N's 3925466, 3927305.
Old Aug 7, 2013 | 08:59 PM
I pulled thermostat from mine and went to napa and auto zone. I got several different ones and none of them even fit in the housing... Apparently something isn't right.
Old Aug 10, 2013 | 09:41 PM
tiremann9669's Avatar
The dumb ***** probably gave you one for a 5.9 Gasser
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
hershwork
Mar 1, 2015 05:15 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
hunt4beer
Nov 15, 2014 09:06 AM
