heat exchanger
Old Nov 13, 2013 | 09:18 AM
ssamco1's Avatar
Default heat exchanger
Hi. New to this site.Be gentle.
I want to bypass or delete my heat exchanger because it is leaking. Can I just run a heater hose around it or is there more to it than that?
1994,single cab 3500 dually,auto,some small bombs,435,000 miles,good runner.
Old Nov 14, 2013 | 02:05 PM
ssamco1's Avatar
Default heat exchanger or trans cooler
Hi
I am getting a lot of lookers but no answers. Perhaps I should of called it by its other name.Transmission cooler
Old Nov 14, 2013 | 02:24 PM
AMS247's Avatar
Yes you can bypass the heat exchanger. It's done a lot for someone adding compounds.
As long as you're not in an area below 0*, you should be fine.
Old Nov 26, 2013 | 01:01 PM
ssamco1's Avatar
help heat exchanger or trans oil cooler
Hi again.
Is there any secrets to bypassing this cooler? What size hyd.hose? Cooler is all rusted and water is coming out where the hose goes into cooler. It has a right I guess, 435,000 miles.
Hello
Me again. I desparately need a blow up of trans cooler to see what lines reconnect to what lines. I see there are four lines. One on ea. end and two underneath. Do the top ones connect and the ones underneath connect? I am approaching my 77th birthday and I my memory isn't what it once was.Help!!!!! If you don't know by now, I am wanting to remove the trans. cooler
Old Nov 26, 2013 | 01:28 PM
NadirPoint's Avatar
Check out this thread from a couple years ago:
https://www.dieselbombers.com/5-9-li...ger-trans.html
Old Nov 26, 2013 | 06:06 PM
ssamco1's Avatar
Thanks NadirPoint for the info. I'll give it a go.
Old Nov 27, 2013 | 07:53 AM
NadirPoint's Avatar
Just don'r use heater hose - not made for oil. General purpose or something specifically made to hold oil.
Old Nov 27, 2013 | 03:31 PM
4x4manonbroke's Avatar
Yeah I would use Hydraulic hose .. good for heat,oil, and high pressure ... and use 2 clamps in each end ....
Old Dec 3, 2013 | 08:14 AM
ssamco1's Avatar
nadir-point
now after geting under truck I see only 3 lines. Do I hook up front line to line running back to radiator and then what. I really need a diagrahm. Thanks
Old Dec 3, 2013 | 01:34 PM
I would run a single line to radiator ( if you want to use that one ) , then tio a separate cooler behind grill drivers side had a small one ... ditch it and get something a bit more substantial, then into that from rad, then out from that unit to the inlet of trans ... and you should be good .. use hydraulic line and two clamps per end and it should never leak .... also see if you can find barbed fittings to use ... these are much less likely to leak or fail..
