Turbo problems need help
Old Sep 19, 2013 | 03:28 PM
eddie7644's Avatar
Default Turbo problems need help
I removed my turbo the other day to replace the exhaust housing. Last night I put it all back on and when I started it up made a funny howl noise. I took it down the street absolutly no spool or anything also when I opened the hood after driving the exhaust housing was smoking like it was either overheated or burning something off. Took it for another drive real quick still no boost then all of a sudden i got 38 psi boost and the truck took off and the howling went away. Pulled back on to my street the howling was back and heard what sounds as if the fins are hitting the housing. Also forgot to mention when the turbo was out had no shaft play now all of a sudden it does. I dont know what caused this anyone have any ideas but pretty much sure the turbo is smoked.
Old Sep 19, 2013 | 09:32 PM
4x4manonbroke's Avatar
sounds like something go bound up in it somehow .... are you sure u aligned the housing correctly if not it will do exactly what your describing ... did it to a 50 series turbo .... thankfully if was already toast for the most part ... LOL........
Old Sep 21, 2013 | 09:48 PM
GbryTxCtryBy's Avatar
Having the same problem, difference is I never took my turbo off... Just got the Howell just after startup. Don't mean to hijack the thread. Just looking for information.
Old Sep 21, 2013 | 10:05 PM
sounds like bad bushings .... need to check it out before the big BANG !!!
Old Sep 23, 2013 | 07:01 AM
eddie7644's Avatar
Yup bad bushings it was I pulled the turbo and had alot of play compressor wheel hit housing a little but not bad. Have a rebuild kit and wheel on the way
avatardvr
18
Aug 8, 2019 12:38 AM
Hogridenfool
Nov 20, 2017 04:37 PM
huntman7
Sep 17, 2015 10:03 AM
n2brk
Feb 21, 2015 09:05 AM
GreenDieselF
Oct 20, 2014 02:05 PM
