12v cummins problem
Old Jul 25, 2013 | 10:52 PM
motoman32002's Avatar
Default 12v cummins problem
ok guys i have a 95 dodge ram 3500hd 5speed with a 12v cummins...i got the truck from a guy that said it had been sitting for 7 months.. It needed some gears in the tranny and was taken apart..... anyway i put a new trans in it got it all put back together changed all fluids and cranked it. upon starting i noticed the truck sounded like it was running rough. when reved up it pours white / blue smoke. cracked open all injectors 1-4 made the motor change tune...when i got to 5 and 6 it made no difference. i put two new injectors in 5 and 6 and started it up same problem it was getting fuel to the injectors tho.!!! guys please help i have alot of mechanical skill just not on a diesel. thanks my phone number is 706-816-9239 thanks all help will be greatly appriciated.
Old Jul 26, 2013 | 12:29 AM
smokedout's Avatar
Fuel filter
Old Jul 26, 2013 | 06:48 AM
biged681985's Avatar
Try a fuel filter first but sounds like timing is pretty low
Ready to be back in a truck
Old Jul 26, 2013 | 07:26 AM
Just curious why would a fuel filter make 5 and 6 have no change but 1-4 change?
Old Jul 27, 2013 | 04:13 PM
NEWBIE 98's Avatar
delivery valves I the injection pump. all the injectors should be flow matched and tested for pop and pressure. its not recommended to replace just individual injectors. The rings could be shot too. check the draft tube and engine openings for smoke and pressure. check the charge air system for oil leaks and shaft play and boost leaks. It sounds like the truck has not been well maintained. Prolly a combination of issues.
burndiesel
10
Feb 7, 2023 01:15 AM
Antwhite19
Mar 26, 2020 04:58 PM
Jonrarick
Oct 25, 2016 01:32 PM
jeremy01995
Sep 14, 2015 06:34 PM
Omingnome
Oct 20, 2014 12:25 PM
