MOTOR IS JUMPING "like the fule is full open and closed"
Old Sep 23, 2013 | 07:02 PM
monstercat's Avatar
Default MOTOR IS JUMPING "like the fule is full open and closed"
I have a 98 12 valve, #10 fule plate, engine break, 4" exhaust, front of the turbo has been upgraded.
My truck started jumping,jurking, surging ect. seems like it is only doing it when I am towing and at lower speeds under 30 mph, almost like there's a broken throttle spring or something. If I push the clutch in and open the throttle it goes away or if I just romp on the throttle it will stop and run fine for a little bit.
WHAT COULD IT BE????????????
Old Sep 23, 2013 | 08:17 PM
4x4manonbroke's Avatar
fuel delivery issue ... check fuel pressure from lift pump to Injection Pump ... let us know what it is
Old Oct 29, 2013 | 08:09 PM
monstercat's Avatar
found that one of the throttle return springs was broken
Also TSB 18-29-97 Rev. A talks about the Vehicle Bucking or Jerking while under light acceleration or driving at a steady speed
