pros and cons on fuel heater delete
Old Aug 1, 2013 | 12:17 AM
smokedout's Avatar
Default pros and cons on fuel heater delete
Just would like to learn about it.
Old Aug 1, 2013 | 08:46 AM
93_Fummins's Avatar
It heats the fuel to prevent gelling, so that would be a con if removed. Seeing as you are in Texass, I don't think you'll have to worry too much about fuel gelling.
Pros: one less thing to worry about leaking or not working properly.
I did an AirDog on mine, so all that stock stuff is MIA...
Old Aug 1, 2013 | 08:59 AM
NadirPoint's Avatar
I removed the fuel heater from my 1st Gen 6 years ago and drove it in sub-zero temps even as low as -20F many times with no fuel problems whatsoever. The fuel heater is a fail safe device intended to save people not smart enough to use a winter fuel additive to prevent gelling. In cases where this becomes an issue and water or moisture is involved, the fuel heater may not do anything for you anyway because the lines freeze up and clog before it even gets to the fuel heater.
Old Aug 1, 2013 | 05:56 PM
smokedout's Avatar
Ok guys thanks that's all I needed
Old Aug 1, 2013 | 08:01 PM
moneypitk5's Avatar
nor will the preheater do anything for the quart of fuel in the lines between the lift pump and the injection pump.
Old Aug 5, 2013 | 01:40 PM
NEWBIE 98's Avatar
it will if it circulates via convection principle throughout he system as it is designed to.
Old Aug 10, 2013 | 02:41 AM
motormayhem's Avatar
I read that it was less for preventing the fuel from gelling and more for melting water crystals so the water separator could still function properly and not damage the lift pump. It is right next to the lift pump though so it probably also helps keep liquid fuel going to that.
torque monsters diesel
Mar 1, 2015 05:20 PM
