Pulling tips
Old Aug 8, 2013 | 10:21 AM
96cummins12v.'s Avatar
Default Pulling tips
I would like to know some tips to pulling. I have done it in a manual but not automatic. The truck is a 96 12v with 684hp. Big single turbo (s472 .9ar) starts making 10psi at 1800rpm and 60psi at 2200 rpm. 250hp injectors, pump work, cam, built gorerend tranny. I am installing suspension stops this weekend and putting my ladder bars on this after. I would like to pull in D if i can to get some speed. I also have the tps delete so i can choose my shift points. I can make the truck shift at anytime up to 3500rpms. I am thinking D direct buy turn the **** to about 2800 rpm to allow for shifts. Should this be in 4HI or 4LO? or should i do it differently?
Old Aug 12, 2013 | 11:10 PM
smokin6bt's Avatar
u go into drive its gonna fall on its face. 4Lo start in first then second and let her eat. pump the brakes and ease into the throttle till you feel the truck and chain stretch, then slowly ease off the brake and into the throttle.
Old Aug 13, 2013 | 11:15 AM
94 12valve's Avatar
need to know gear ratio and tire size ... do you have a converter lock up switch?
Old Aug 13, 2013 | 05:56 PM
lock up switch 3.55 gears and 35 tires bout 45% tread
Old Aug 13, 2013 | 07:41 PM
4x4manonbroke's Avatar
u need more gear IMHO .....
Old Aug 13, 2013 | 07:55 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
2nd gear low range with those gears
Old Aug 13, 2013 | 08:24 PM
I know in second gear at the end of the track my truck will fall of its face with this big charger. I need wheel speed and keep wheel speed
Old Aug 14, 2013 | 11:24 AM
94 12valve's Avatar
I second this
right as you feel the pan hit unlock your converter. A bigger gear will not help the falling on its face issue and to get more wheel speed you need more horsepower.
Old Aug 14, 2013 | 04:32 PM
But when the pan hits I'm gonna lose my rpms without maintaining that wheel speed. This turbo doesn't make good boost till 2100rpm so I'm thinking more 4lo Drive, turn my shift points to 2700rpm and before the pan hits unlock the converter
Old Aug 14, 2013 | 06:07 PM
94 12valve's Avatar
4low in 3rd gear is way too big of a gear your not going to be able to turn it with that rear gear and tire size
Brclouse
Nov 18, 2015 08:44 AM
oneloud59
May 16, 2015 10:00 AM
rack1234
Mar 28, 2015 09:56 PM
hulse09
Feb 3, 2015 08:18 AM
