Help!! Injector Selection
Old Aug 26, 2013 | 06:22 AM
Tyler Smoot's Avatar
Default Help!! Injector Selection
My brother has a set of custom built 5x16's, he is building his truck for a twin turbo setup, he just had the trans built, he has a 0 fuel plate and 181 DV's. He is wanting to put the 5x16's on the truck now while the trans in the shop, so he can run the trans through its courses, will those injectors be wayyy too much for stock charger til the twins go on the truck? Will he be able to keep smoke to a very minimum?
nobody can answer this?
Last edited by Tyler Smoot; Aug 26, 2013 at 06:22 AM. Reason: Automerged Doublepost
Old Aug 26, 2013 | 08:05 AM
lukesdiesel's Avatar
He will smoke like a freight train.
Luke
Old Aug 26, 2013 | 08:14 AM
ive ran 5x14 on a stock charger before it wasnt bad, as long as you kept your foot out of it it was just a haze like 370's, are the 5x16 that big? i personally dont see them being out of control but i may be wrong
well for example put it like this, if you had to jump in your truck and make a trip to the store with the 5x16 in it could you make the trip withno issues?
Last edited by Tyler Smoot; Aug 26, 2013 at 08:15 AM. Reason: Automerged Doublepost
Old Aug 26, 2013 | 10:56 AM
jkidd's Avatar
stock turbo is rated for 325HP. 5x.014 can get you to 500-550HP without too much effort 5x.016 at least another 100HP
if you were to go with a 64mm turbo and 5x.014 you would likely see about 200egt reduction and 50HP more since the hx35 is restrictive down to about 2" right out of the turbo (it makes the 5" exhaust nearly a useless upgrade except for it is louder.)
