2nd gen trans questions.
Old Aug 12, 2013 | 03:42 PM
tom88k5's Avatar
Default 2nd gen trans questions.
Im in the middle of doing a cummins swap and I have a 2wd 47rh and was wondering if I could use the 4x4 od unit off a 48re? I can get one for fairly cheap. Any info is appreciated. Thanks in advanced.
Old Aug 12, 2013 | 08:28 PM
4x4manonbroke's Avatar
I would contact a trans shop .... but I do believe you can ..... as I recall the 48 had a bigger drum in the OD for the bigger trucks like the dually 1 ton's ...
Old Aug 12, 2013 | 08:47 PM
tom88k5's Avatar
Alright thanks
Old Aug 12, 2013 | 11:22 PM
RedChevy44's Avatar
The 47rh is hydraulically controlled so it has a governor in the O/D unit. The 47re and the 48re are electronically controlled so they dont have a governor, which you have to have in your transmission for it to work. Many of the parts inside will work for the 47rh though.
Old Aug 13, 2013 | 05:54 AM
tom88k5's Avatar
Cool thanks. So thats a no go. Guess ill keep my eye out for a divorced tcase then
PA 24valve
Aug 31, 2015 07:39 PM
CGwill
Jan 26, 2015 02:10 AM
JMan96CTD
Jan 24, 2015 11:16 PM
Cumminsfreak24
Jan 21, 2015 09:10 AM
myago92
Oct 17, 2014 08:50 AM
