Cat turbo
Old Oct 28, 2013 | 11:02 PM
2manytrucks's Avatar
Default Cat turbo
I came across a cat turbo and was curious if anyone knows anything about it. It's brand new not a reman. Here's a pic of the tag.
Old Oct 28, 2013 | 11:42 PM
NEDieselCore's Avatar
Cat acutally uses alot of the same turbos on diffferent engines. They use a wastegated and non-wastegated model accross a few engines.
Old Oct 29, 2013 | 05:38 AM
turbo2332's Avatar
chances are its a s200. and many times they have a 58ishmm compressor by 60mm turbine. they are pretty good for stock replacement. comp wheels are much taller than a stock holeset and will move more air. the turbine is a very open design and flows well for its size. does it have a circle cover for the wastegate or the 5 bolt cover? either will work. it will be gated for around 22psi. i will look you P/N up @ work today and get you a little bit better info. but we sell our cat remans for like 8-900 reman and new is around $1200. if your in need of a replacement charger i would snag it.
avatardvr
18
Aug 8, 2019 12:38 AM
n2brk
Feb 21, 2015 09:05 AM
Whitereaper12v
Jan 28, 2015 11:01 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
