Putting a 727 in a 1994 2500 4x4
Old Oct 3, 2013 | 04:08 PM
lowered22t's Avatar
Default Putting a 727 in a 1994 2500 4x4
Needing some advice and help my 47rh is crapping out and having a hard time finding another one or a master rebuild kit. Was told I could use a 727 and it would bolt right in will it and what do I need to do
Old Oct 3, 2013 | 09:02 PM
RedChevy44's Avatar
Finding another one might be hard, but you can find rebuild kits easy. Look on Ebay, it uses the same clutches as the 47re. I wouldn't put a 727 in there, these trucks need more gears, not less. What is your transmission doing?
Old Oct 3, 2013 | 09:10 PM
4x4manonbroke's Avatar
yeah a 727 would be pointless ...
Old Oct 4, 2013 | 05:37 PM
lowered22t's Avatar
It's slipping in fourth gear pulled the pan and there was clutch material in the pan
Old Oct 4, 2013 | 08:26 PM
its not too much more difficult than building 727 ... just don't attempt to pull the OD apart .... 800# spring will knock you on ur ***
the forward half is easy ... buy a master kit , build the front half your self, have a local shop do the OD, and stuff it back in ... set ur line pressures around 175 and you should be happy .... and it will last
Daniel Finney
Oct 22, 2019 01:58 PM
Renteria1217
For Sale
Aug 16, 2015 09:43 PM
river rat
May 18, 2015 05:04 PM
hoeky22
For Sale
Mar 15, 2015 08:35 PM
gladeslife
Sep 27, 2014 11:32 PM
