flywheel question
Old Nov 15, 2013 | 05:11 AM
maddog5008's Avatar
Default flywheel question
will a first gen flywheel work on a second gen motor? I was offered a new 13 in clutch kit with a flywheel but after running the numbers found out it was for a first gen cummins. thanks in advance
Old Nov 15, 2013 | 07:02 AM
Kbnecessary's Avatar
it should work just fine all the 13 in conversions the valiar offers are the same for all the 12 and early 24 valves
Old Nov 15, 2013 | 09:51 AM
4x4manonbroke's Avatar
it's not that big of a difference .... Chevy did the same with the 11 & 12 " clutches .... it was like a sb to bb difference ..
Old Nov 15, 2013 | 09:11 PM
maddog5008's Avatar
I was told my starter wouldn't work and that the first gen flywheel wouldn't work because its diameter was bigger than my stock second gen flywheel and wouldn't fit because of the bell housing adapter was different
what modifications have to be done to make it work?
Last edited by maddog5008; Nov 15, 2013 at 09:11 PM. Reason: Automerged Doublepost
Old Nov 17, 2013 | 05:21 PM
what clutch is it that might help some most 13" conversion come with a flywheel that fits all of the 12valve is it a valair or southbend part number might even help to
Old Nov 17, 2013 | 06:41 PM
maddog5008's Avatar
It is a Valair. Part # nmu0087-01
PA 24valve
Aug 31, 2015 06:08 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
TMP025
Chevy/GMC Duramax 01-04 LB7
Feb 16, 2015 12:27 AM
BCOWANWHEELS
Wanted To Buy (WTB) - Used
Dec 11, 2014 07:29 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
