Urgent!!!!!!!!! Exhaust manifold....
Old Aug 30, 2013 | 11:24 PM
White96cummins's Avatar
Default Urgent!!!!!!!!! Exhaust manifold....
So I got my gauges and I was drilling into the exhaust manifold.... Drill bit got stuck and the only way to get it out was but force which lead to a bigger hole than what I needed for my egt probe.... is there any adapter I can buy? Or am I sol and have to get a whole new manifold? I've tried the quick steel xtreme.. But fails. I need help ASAP!!!!
Old Aug 31, 2013 | 12:09 AM
RanchhandTCR's Avatar
try to find a coupler tomarrow that will adapt to the current fitting, and drill and tap for the coupler..
Old Aug 31, 2013 | 12:29 AM
RedChevy44's Avatar
I accidentally drilled the hole to big in mine so I set the fitting in the hole and welded it up. Probably not the best thing to do but it has worked fine for me so far (stock power levels though). I have not seen a crack or anything yet.
Old Aug 31, 2013 | 06:45 AM
JBearSVT's Avatar
Any Home Depot or Lowe's should have what you need, it's called a 1/8"NPT - 1/4"NPT bushing. It will allow you to drill and tap the hole to the next size up and still have the probe enter the manifold to the same depth.
Old Aug 31, 2013 | 08:59 PM
MikeRodrig27's Avatar
I have a '97 manifold if you're interested. Let me know. You can drill/tap larger for a get me by and then do a new manifold.
Old Sep 1, 2013 | 01:30 AM
Thank you all for the help!!!!!! I went and got a bushing drilled and tapped it and it worked! Idk why I didn't think of that first!
Old Sep 1, 2013 | 05:32 AM
JBearSVT's Avatar
Old Sep 2, 2013 | 10:40 PM
4x4manonbroke's Avatar
its often our first responce to freek out ..... then think last
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Jake12valve
May 10, 2015 11:57 PM
Old12er
Feb 20, 2015 10:35 PM
cummins Pride
Oct 23, 2014 01:10 PM
