97 dodge cummins
Old Jul 27, 2013 | 06:08 PM
colokerrie's Avatar
Default 97 dodge cummins
97 Cummins 4 wheel drive. I just put a actuator in it . it still seems to not to be getting any vacuum. everything cks out on the transfer case working . any ideas . I am deff a roofer and not a mechanic
Old Jul 27, 2013 | 08:28 PM
tiremann9669's Avatar
Probably a vacum line leak going to the actuator.
Old Jul 29, 2013 | 05:59 AM
NEWBIE 98's Avatar
what he said. check the two lines going to the actuator on the axle back to the transfer case and to the vacuum pump most are a semi ridged plastic or steel and have rubber wye and tee fittings that get broken down.
Old Jul 30, 2013 | 10:21 PM
colokerrie's Avatar
ok I ck the lines and they looked ok . I changed the sencor on the axel. still no 4 wheel. should I take the actuator off and engage the wheel to make sure axel is working
Old Jul 31, 2013 | 10:44 PM
TurboHyde's Avatar
I had the exact same problem on my 97, I replaced and checked and double checked everything and never could find the problem! So I said screw it and bought one of these 4x4 Posi-Lok - 4WD Engagement Systems. I have never had a problem since, well worth the money and so easy to install.
Old Jul 31, 2013 | 11:08 PM
colokerrie's Avatar
How much did that cost
Old Jul 31, 2013 | 11:20 PM
TurboHyde's Avatar
for everything plus shipping i think i paid right around $200, but I got that straight from the companys web site, you might be able to find it cheaper on like ebay or amazon
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
Linkbeltpower
For Sale
Dec 15, 2014 10:52 PM
Nov 4, 2014 08:10 AM
kamwil54
Nov 2, 2014 08:48 PM
