throttle cable
Old Nov 3, 2013 | 11:27 AM
Bashore Farms's Avatar
Default throttle cable
my foot pedal to accelerate only goes down about half way and stops? any suggestions?
Old Nov 3, 2013 | 11:30 AM
4x4manonbroke's Avatar
check your line from the fire wall to the IP ... your binding ... try to move it to Full throttle with it not runing ... something is outta wack ... Have you recently replace anything ?
Old Nov 3, 2013 | 11:34 AM
no I haven't replaced anything in awhile. It doesn't stick or anything at all just only goes down about half way and then it feels like when the pedal is to the floor. but its not
Old Nov 3, 2013 | 11:42 AM
the hard line is probably binding or your cable is shredding inside ... you will need to pull the cable off and diag wich one is faulty .... chat with ya after church ..
Old Nov 3, 2013 | 11:58 AM
okay I have a new throttle cable should I put it on?
Old Nov 3, 2013 | 12:35 PM
Dortiz's Avatar
Possibly one of the throttle return springs broke, friend of mine had it happen and would have to stomp on the pedal to get past the "hard spot"
Old Nov 3, 2013 | 04:59 PM
that's what it is. I took the cable off and it was fine, then I looked at the return and moved it and it was hard to move so its the spring. Thanks for the help guys. bought a throttle cable for nothing but its good to have spare parts!
Old Nov 3, 2013 | 05:06 PM
JBearSVT's Avatar
I threw the return spring away about 120,000 miles ago and never had this issue. WTF.
Old Nov 3, 2013 | 09:30 PM
dodgerammer97's Avatar
I m new here, but the throttle assy have been on the recall before so I would suggest that you call your nearest dealer ship and give them your vin number and see if you are covered ok good luck
Old Nov 3, 2013 | 10:27 PM
Could be ... I have herd this manny times.... need to call mine in ..,.. just cause im tired of throwing money at it ... someone else needs to chip in a few bucks here n there
Colbyflory
Aug 16, 2021 09:19 AM
12vWoodHauler
Sep 30, 2015 07:58 PM
Blair@BD
BD-Power
Sep 10, 2015 12:29 PM
1stgenswap
Nov 3, 2014 09:45 PM
T Mack
Oct 19, 2014 11:39 PM
