Tranny shudders when engaging lockup switch
Old Aug 11, 2013 | 10:14 AM
Luke7's Avatar
Default Tranny shudders when engaging lockup switch
Hey guys Luke here. I am new to this forum however have owned my 97 cummins for 3 years. I have just a handful of mods: exaust,bhaf, no fuel plate, pump tuning, 3000 gov springs, timing 16.5. A year and a half ago I had my local tranny shop rebuild my tranny and had them put in a triple disc converter and upgraded valve body. Here recently I've noticed when I lock my tc up usually around 35-40mph and about 30% throttle the truck shutters but doesn't feel like its slipping. The owner of the trans shop has since past away so I figured you guys may could give me some things to try before I deem my tranny bad. Thanks in advance guys
Old Aug 11, 2013 | 08:50 PM
turbo2332's Avatar
the shudder is the TC slipping. what brand converter did you install? i would drop the pan and look for metal and clutch material. if you are slipping fluids will wear faster be burnt smell bad ect. give it a good look see.
Old Aug 11, 2013 | 09:22 PM
Luke7's Avatar
Thanks for the reply. I don't know what brand tc it has prob not a reputable brand. I am guilty of hitting the lockup switch at low speeds to get up to speed but I don't beat on the truck. I just bought fluid and filter today to do change. Also another bit of info it seems to do it more if the trans is cold could it be me causing it? Also I've read about the yellow/black wire being removed from alternator will help. I have a feeling it's the tc going out but I have a child due next month so I really can't fork out the cash so I want to try everything to fix it if I haven't gone too far. Thanks again turbo2332
Old Aug 12, 2013 | 12:25 AM
lukesdiesel's Avatar
Diesel Performance Converters
Luke
Old Aug 12, 2013 | 08:33 PM
4x4manonbroke's Avatar
Ok I know what u problem is .... the stator inside the TC had become out of balance and has most likley it will get worse ... until it pops off the shaft inside ..I had to pull mine finally ... bought one from Car Quest .. HD low stall converter ... stalls at about 1700 instead of 1900 ..... said it will hold about 700 LB/Ft torque .... working great ... my cost was 450$
Old Aug 15, 2013 | 12:15 PM
Luke7's Avatar
Thanks for the advice I will consider buying. I got ahold of moparman1973 and he told me I could be switching to lockup at to slow of a speed and I could have this issue when the tranny isn't up to operating temp when engaging lockup before overdrive so in going to try what he recommended and see if it makes a difference. If not an going to get a new tc
cumminspwr11
12
Oct 17, 2021 03:50 AM
rstrange1996
Sep 22, 2015 01:25 PM
Ryans71
Diesel Engine Conversions
Dec 24, 2014 08:47 AM
IslanderXJ
Dec 17, 2014 04:14 PM
Tower crane guy
Oct 22, 2014 06:04 PM
