Torque converter will not lock tried everything please help
Old Nov 27, 2013 | 08:58 AM
ebarresi5894's Avatar
Default Torque converter will not lock tried everything please help
1997 3500 12v 168k automatic
The torque converter will not lock.
Does go into o/d however
I've tried:
Adjusted tps to 1.0-1.1v
Adjusted tv cable
Checked ground at tps works
Checked brake switch
Checked throttle rod at 5"
Checked AC current at alternator (0volts)
Checked trans relay
Code 1224, not sure what to do
What else is there to check?!?
Please help this is my dd for towing cars
Tried a lock up switch and still nothing
Any input
Last edited by ebarresi5894; Nov 27, 2013 at 08:58 AM. Reason: Automerged Doublepost
Old Nov 27, 2013 | 09:31 AM
mysterync's Avatar
I've tried:
Adjusted tv cable
Checked trans relay
Any input
Solenoid, no power to solenoid , crap in the valve body or conveter.
Sent from my SCH-I605 using Tapatalk 2
Old Nov 27, 2013 | 03:15 PM
4x4manonbroke's Avatar
sounds like the clutch has let go ... what is the state of your trans fluid ? ... smell burnt ?
might try and just drop pan, install new filter and re-fill ... but I'm betting your TC is not good .... - (Common issue with any dodge ) .. even the newest ones
Wizbangdoodle
Ford Powerstroke 08-10 6.4L
Sep 26, 2015 02:47 PM
alysiamc
Jun 19, 2015 02:03 PM
cumminsbred01
Feb 17, 2015 12:26 PM
Jgloveracob
For Sale
Dec 7, 2014 10:47 AM
Tmaxxrox97
10
Nov 10, 2014 10:37 PM
