BD Power Transmission not shifting right.....?
Old Nov 23, 2013 | 09:07 AM
bkoso85's Avatar
ATTN BD Power Transmission not shifting right.....?
Hey guys,
I just picked up a 12 valve and it has a built BD Power Transmission. It almost seems like its slipping when you hammer on it.
Fluid is nice and clean, not burnt, fluid level is good. I was looking at TV Cable adjustment but can't really get a straight answer on how to adjust it right on the aftermarket transmission.
Most of the time its just shifting very quick it seems. Then when I go WOT getting on the freeway it hesitates.
Can anyone help me out?
Thanks!
Old Nov 24, 2013 | 09:26 AM
bkoso85's Avatar
Bump. I got some of it working better. But under WOT its shifting about 2800 RPM's. And kickdown does not seem to be working that well.
Old Nov 24, 2013 | 09:32 AM
mysterync's Avatar
It would be best to find a good transmission shop thats got experience with aftermarket setups and ask them to diagnose the issue!
Sent from my SCH-I605 using Tapatalk 2
Old Nov 24, 2013 | 09:35 AM
bkoso85's Avatar
That's the problem. There is none any place close to me.
Old Nov 24, 2013 | 10:04 AM
mysterync's Avatar
This isn't a repair thats suited for a diyer. I think I would recommend finding a good shop!
Old Nov 24, 2013 | 10:07 AM
bkoso85's Avatar
What kind of repair do I need? I would like to find the correct way to adjust the TV Cable. I read a couple different methods but nothing set in stone.
Old Nov 24, 2013 | 10:28 AM
mysterync's Avatar
You need a diagnosis from a competent technician. Throttle valve adjustment is basically when the throttle begins to open the tv moves at the same time.
Old Nov 24, 2013 | 04:09 PM
4x4manonbroke's Avatar
Where are you located ? some one might know of some one around your area that will be able to help and get ya straightened out....
Old Nov 24, 2013 | 04:35 PM
bkoso85's Avatar
North Idaho / Coeur d' Alene area
Old Nov 24, 2013 | 04:43 PM
mysterync's Avatar
I know atptrucks.com (idaho rob) is in Eagle or Boise and while they specialize in duramax they may help you find what you need.
fivepointohno
5.9L CR Performance
12
Jan 25, 2016 01:07 PM
SixSpeed
Jan 11, 2015 01:41 AM
