- Confusing running issues
- 96 6.5 wont start NEED HELP BAD
- glow plugs 6.5 td
- 1995 Gmc 2500 pops and sputters, AND TAKES OFF?!
- used engine oil for fuel
- 6.5 turbo intercooled HZJ105 R Toyota
- 1998 Chevy 6.5, revs to 1000rpm but thenld its self there
- 250k + miles on my 6.5
- 6.2L rebuild???
- KING PINS?????
- 6500 and penn 400 redisgned block
- 6.5 with 193k miles
- 6.2 diesel glow plug relay LOUD
- Oil Cooler line removal
- Boost gauge hookup location
- What is a good code reader to buy? $150 budget
- 6.5 oil pressure
- New Lift Pump needed - get the higher PSI for a 93 or the one listed for my year -97?
- Why do PMD's go bad/autozone PMD
- 1984CUCV M1009
- '97 6.5 Diesel Tahoe 2 door 4x4 for sale
- Irratic idle on my 6.2L 84' suburban
- 6.2 Fuel Filter Housing
- old 6.5 TD to newer 6.5 NA parts compatability
- Any Ideas
- Chevy 6.5 basic questions
- 1998 6.5 coolent in oil
- White Smoke
- Cummins swap
- 92 3500 Tire Size?
- Cold start problems..
- Glow Plug Driver
- 6.2 fuel problems
- Big time upgrades?
- blocked wastgate?
- after installing lift...driveshaft problem
- 85 M1010 6.2 Random hot start issue. Now starts to die randomly
- Looking for M1009 in NE OH
- 92 chevy 6.5 turbo service light issue
- What Alternator To pick???
- Starter engage when Fuse for Glow plugs in
- 95 gmc coolant comes out of overflow tank
- Forum problems?
- 6.5 Boost and Vacuum Mixup
- 6.5 Normal oil pressure?
- Truck just died going down rd
- engine bracket
- PMD problem fixed.
- more power
- wheel spacers!! HELP!
- Oil catch can on "tuna can"
- leaf spring spacers
- 6.5 engine back pressure
- Problems with adding turbo to 6.2?
- 6.5 head gasket
- 95 k2500 won't come out of 4wd
- Blown OPS within a few weeks
- Just wanna know!
- 6.5 Lack of acceleration
- I think I just might cry
- trans still acting up
- K47 air filter housing
- Need a cheap Pmd relocation Kit
- oil pressure switch question
- 95 6.5 no power but plenty of smoke
- code 21 for TPs
- 75' c-10 scottsdale 6.5 swap
- 6.5 shutting down
- flywheel question???
- no glow plug light
- repeat issue, still no answer
- fds diagnoises
- way to much boost
- Truck seems to run fine but SES light comes on constantly
- 6.5L No glow plug light plz help!
- Electrical nightmare
- 2000 k3500 6.5 glow plugs not operational
- 6.5 Turbo Problems?
- 94 Chevy 6.5 Surging
- How To: Bleed 6.5L Fuel System
- 1998 6.5 Died and No start
- 6.5, no power, starving for fuel?
- 82 chevy c20 6.2 cranks really slow
- injector pump solenoid
- 99 6.5 exhaust
- Starter troubles 94 Chevy K2500 6.5 turbo
- Stock Suburban 6.5 Overboosting!?!?!?!?
- help suburban 6.5
- Dies but will usually immediately restart.
- 94 yukon diesel
- weird ride home
- RPO Code Reader
- Rusted Brake Lines
- delayed shut down
- head swap, raises compression?
- 94 6.5 no get up.
- What oil are y'all using?
- 1998 Chevy 6.5, wont start, but will pop off
- 6.5L marine injectors
- I want to buy this truck what should I watch out for?
- Rough run on start up
- Thinking about buying a 1995 6.5l 5speed turbo diesel
- 94 6.5 no start
- Doing some work on Dad's 6.5 !?!?!?
- 96 gmc diesel dump
- will a 99 6.5 work in a 94 6.5
- irratic power surges idling or driving
- problem runs bad after new injectors and new injector pump
- 98 6.5 no power stalls after 15 minutes of driveing
- Terrible idle onset when warm
- injectors
- How to get PMD out in less then 10 minutes
- Injector Pump timing
- crank no start
- EGR issue
- Coolant flow deflector retrofit
- power mounted driver brand new
- 1998 Chevy 6.5 Died and wont start
- Hibernation!
- frame modifications
- starving for fuel. HELP!!!
- turboed 6.2 project ideas
- 6.2 diesel 150 hp 330 lbs torque
- 2 cycle oil in 6.2 diesel
- white smoke at start up
- 6.2 black smoke
- New PMD, Still Dies
- 95 6.5 Turbo T-Valve problem, Please help!
- Why would a Vacuum TCM be on a 6.5 td?
- 93 chev 6.5 fuel problems
- Spindle Lift Kit C3500
- nexiq 125032,heavy duty diagnostic tool,obd2 Diesel Software,diesel truck diagnostic
- 6.5 swap fuelpump ?
- 6.5 trouble
- Hand Crank 6.2 diesel
- 95 Chevy 6.5 stalling please help
- 94' Chevy 6.5 turbo diesel increasing idle and smoke
- Use transmission cooler as oil cooler
- Electrical problemos
- Fuel in crankcase in my 93 6.5 GM
- Looking for a bit of lift
- Mayham call need your help!!!!
- Thanx for the help
- 6.2 doin work
- cluster goin haywire
- Radiator question
- trying to put body lift on diesel burban
- 1992 where can i buy a mechanical injector pump?
- 1992 td 6.5 what is the T vavle for and how does it work
- 1992 2500 td wont run
- Bad FI pump? what is a good diagnostic tool
- 1996 suburban need mechanic south AL
- spits and sputters wouldnt run over 20mph
- '96 Suburban 6.5 Turbo Diesel
- 4L80E transmission swap
- 1996 Suburban optical sensor
- Homemade Turbomaster!!!!
- replacment throttle cable???
- 1990 6.2 running warm when towing
- help identifying door handles
- 93, 6.5, i want it reliable and fuel efficient
- VERY CONFUSED 95 GMC 6.5 TURBO DIESEL
- Smoke a little even at idle.
- 1996 chevrolet 6.5 turbo No start No smoke.
- home made turbo master questions
- 95 GMC Surges and flutters when ideling runs great down road
- 2000 chevy 3500
- wanting to know about 18:1 pistons and intercooler on 6.5 turbo
- 1996 K2500 Burb 25+mpg? Possible?
- 6.5 personal opinions??? Help !!!
- First things to check/change/and upgrade??
- Erratic idle & rough start
- 6.2 diesel/m90 eaton
- 6.5 turbo diesel clutch fan question
- 1993 chevy 6.5 td needin guidance/advice
- On the job
- db2 swap in 94 6.5 td
- 96' 6.5 Burb advice please....
- dome light mystery solved
- 6.2 barely pulls 6200 lbs?
- New paint
- 1992 Chevy 2500 6.2L Non-Turbo Problems
- first post!
- What to do now?
- My suburban, starting problems!
- diesel gauge pod for 80s chevy diesel
- how do i ckeck my ignitio switch
- CAN I GET A LITTLE HELP PLEASE I AM STUMPED 6.5TD
- 1997 savana 6.5 turbo diesel issues
- 6.2 detroit vs 6.5 detroit horse power
- #9 resister
- New to me 98 CC DRW
- What the truck???
- 1995 6.5 no glow plug light no start
- 6.5 trans temp gauge
- Hybrid???
- Dieselize Suburban
- i'm stumped
- Pop Test Specs
- New Here New Truck
- TH400 no reverse
- bell housing
- Selling a 6.5 tb 2 door Tahoe?
- 6.5 turbo diesel boost gauge?
- Getting fuel...but not enough?
- I'm lost
- fuel issues on 6.5
- 1995 K2500 6.5
- 99 6.5 turbo diesel
- 95 chev Tahoe 6.5tb- hood insulation needed?
- 94 Chevy cd 46 mil circuit fault
- Wiring for fuel pump
- Transmission swap
- 6.2L in 85 S10 Blazer?
- Custom Cold Air for Banks Turbo 6.2
- IP gear pin thingy
- 6.2 problems
- throttle erratic, smokes like a freight train
- Injection pump issues
- How much Boost can a stock 6.5 safely handle?
- wiring up airplane landing lights
- runs bad at half throttle
- 6.2 won't start now
- Longer to start then black smoke
- New windsheild
- 1999 6.5 engine swap
- 6.5 turbo sputtering and blowing more black smoke
- Lost Tac display
- New to DB looking to buy a 6.5
- 6.2 vs 6.5 Perfect Build
- biggest tires on back of dually
- price my truck
- 94 1/2 ton 6.5 wont start
- stanadyne frenken pump rebuild
- Solid axle swap
- PM in the PNW
- 13 gallons to the mile
- 6.2L won't rev up has no power. lots of smoke.
- New to the 6.5: Having electrical problems
- wastegate?
- 6.2/6.5 in pdx
- 4L80E problem
- Starter Fix On The Cheap
- chevy 3500 6.5 turbo injector problems
- 1995 6.5 wastegate actuator
- Found "rare" truck. Thoughts please?
- need some help sbc to 6.5 swap
- military ip help
