- Head Gaskets
- wheel and tire help asap please
- Top Speed Eliminator
- 24 valve build up help.
- raptor 150 install
- Quadzilla Adrenaline 4K
- P-Pump conversions
- HT3B vs s400 twins
- Diesel pro cam first impression!
- Box stacking ?
- snubber not workig?
- power questions
- head gasket
- steering box
- TST Comp with Edge Comp stack
- Hood Stack Answer
- Headstud questions
- Edge Juice w/Attitude mounting spot
- Boost Elbow
- egt gauge install
- best track bar
- Head studs
- Grid Heater delete
- super phat shaft 62/71/14
- Try an hx40 turbo??
- fuel PSI gauge help
- BD lift pump
- looking for a turbo
- Best a-pillar gauge pod?
- Edge messing up
- superchip max micro tuner?
- snapped spacer plate!!
- nv5600. need help!
- my pull at Brighton (Seminole) 13 March 2010
- Clutch??
- bitting the bullet transmission time!
- rpms on vp
- Gauge install
- 175hp injector?
- SO pump or hotrod/monster??
- Quadzilla Xzt?
- daiblo power puck
- fuel presure
- fuel presure
- Some Pictures Of My ADR w/ Pulse, K&N Intake, And AirDog 150 Install
- FASS DDRP Anyone use one?
- Time for a new box....
- transmission?
- port and polish?
- tapping my pump?
- 62/71/14 turbo
- Camshaft or .093 tubes
- 4" or 5" Turbo Back Exhaust
- Air Dog 150 Install Pics
- Quad Adr Tunes
- Turning off torque management
- Fass DDRP
- P-pump swap pointers
- switched from edge to quadzilla!!!
- fuel pressure
- Isspro Ev2
- Air Dog 150 starting issues?
- Fuel??cheaper than a airdog??
- Fuel pressure gauge
- Exchanging my EV2's for Edge or ADR?
- Twin Turbo Setup help for 98.5 dodge
- 98.5 24v auto 4x4 quad cab 3500 PCM
- Edge Comp
- Where To Find 2nd Gen SPORT Projector Headlights??
- priming the vp44
- "Howling"/"Owl Call" sound when under no/little load at high RPM!?!
- Power inhancers ???
- PDR Hx40 turbo
- Weird idle?
- squealing
- power
- crankcase evacuation system?
- best vp44 control
- cost of p pumping a 24 valve?
- Torque convertor lock up switch
- injectors
- twin turbo help!
- 12 VALVE CAM IN 24 VALVE
- pulse
- ideas on more low end
- Where to mount an Airdog 150?
- diablo sport power puck or edge ez
- head gasket
- smarty+edge juice.best setting's
- clutch?
- EGT'S
- PCM and programmers
- pyrometer
- crossover tube
- ddrp relocation kit?
- Holset Super 40
- Lopping
- Isspro EV2 Fuel Pressure Gauge
- Performance Package is coming!!!
- Does anyone know where I can get a good deal on a LP?!?
- Sport Headlight Conversion - Which Harness?
- connector tubes
- Injectors
- Best Bang for the Buck
- Air Dog fuel press jumping
- Air Dog 100 or 150?????
- Adr with Pulse
- Edge Products
- smoke switch
- Looking for a good LP for 1998.5 cummins
- Looking for some 75hp injectors?
- Just bought 98.5 24v whats the best way to get power and smoke?
- edge comp
- injector lines,tubes
- fuel pressure gauge 98.5 24v cummins
- edge drag comp and 65 hp injectors?
- questions on downpipe
- --mods, mods, mods!--
- Industrial Injection News
- Chip Stacks
- edge juice/attitude gauges
- how much smoke is a bad thing?
- how much power?
- EDGE Juice w/Attitude
- what kind of power???
- raptor100 or raptor150?
- Banks High Ram 3.5
- Mastercraft Courser CT
- turbo
- Time for a turbo upgrade...
- thinking its time for a cam.
- Few questions on mods
- xzt+ info
- edge ez
- Injectors vs. Nozzles
- fass install
- temperature
- Aftermarket 47RE Torque Converter Q's
- Tapping pump?
- injectors
- low Boost High egt's
- how much power???
- help!!! help!!!!
- NV5600 parts
- Injector upgrade
- The 24v Cummins Injector Bible
- some questions??????
- getting started
- Clutch
- got my smarty...HOLY CRAP!
- ts performance mvp
- BD- super B special
- ok to run 2 stroke in my fuel with an air dog 150? Read more: http://www.dieselbo
- INJECTOR Questions
- Garrett Turbo Surge
- programmer ?'s
- Programmer????
- transmission info time
- exhaust tip
- S366?
- need adr help please
- SUPERCHIP for 1998.5 dodge cummins?
- RBP black grille for 01 2500
- bully dog injectors?
- Hypertech programmer?
- HX50
- need some help.
- Sct Tuner
- Question On PVC Intake Tube Build
- Locker for a Dana 80
- Head studs and o-rings
- Lift Pump
- quad xzt
- would this help?
- Intake Tubes- Do they Help?
- Dodge Cummins Breather Kit
- he351
- B.D injector nozzle's??
- TS Performance Chip?
- A not too funny joke
- Side Exhaust
- quad adr
- Will this make good power?
- My New Fireball 150 Injectors- WOW!!
- How can I get it to smoke???
- gauges
- Airdog 100 Fuel system install
- Tapped Pump VS Bigger Injectors
- edge comp drag box
- Anyone get there edge wet?
- ATTN: 1 pc NON projector headlight users!!!!!!!!
- trans temp. gauge install
- Quadzilla Xzt
- 500 HP
- Turbo advice/recommendations
- 99' map sensor
- Tsts Power max chip
- traction bars
- tripple disk
- quad adr ?
- Will new nozzles effect pop pressures?
- Heavy duty spring clamps
- water meth
- hx40 Turbo
- Injectors
- diablo power puck or quad xtz+
- Did I get a deal or what!?
- My pesky LP
- About Quadzilla boost fooler?
- edge or adrenaline?
- JVD box?
- Trans Temp
- Banks Big Hoss
- What should my next upgrade be?
- Injectors
- What trans to get
- PM3 Comp WOW!!!
- Another lift pump question
- 5.9 Cummins 24V Injector nozzle installation
- Glow shift gauges.
- Future turbo
- aurora 4000
- Surging?
- Let's Talk Cam's Here
- Quadzilla Adrenaline, get it or not?
- tell me about my turbo
- Ummm wtf???
- quad adr and smoke?
- air mods???
- cool little mods?
- Cat Air Filters?
- silencer ring?
- what rims look good???
- Banks power elbow?
- Stealth Plate Install
- bully dog bully box hookup
- Replacement Seats
- Rear axle swap
- Raptor vs. Air Dog 150
- DIY 3rd brake light
- engine work. what is the gains as in hp
- Just Put On My New Diesel Bombers Decal
- raptor
- horspower and fuel milage
- Got a power puck for x-mas...
- 2nd Gen Dodge Control Arms
- some Questions
- Quad addr problem
- What is involved
