- Edge JWA question
- turbo housing question
- What exhaust system?
- nv5600 upgrades
- #6 Injector is a .....
- Smarty Update Question
- Diesel Auto Power problems?
- HELP!!!! Tranny 911
- vp44 cam ring?
- Snow performance help
- What clutch?
- Which Pump to Choose...
- iQuad loading tunes and warning light question !
- 94 to 98 trucks
- 75hp sticks & snow 2
- snow performance stage 2 kit
- he341 turbo swap
- need a idea on a chip
- Adrenaline 4k box
- turbo upgrade ?
- How much fuel should flow
- running out of fuel on top end
- XRFC Ball Joints?
- chip
- quadzilla help
- boost fooler with j hook
- whats the best chip for a 99 cummins
- Whats the best order for buying these mods?
- Fass questions
- lowering egt;s
- Which injectors for my setup?
- Tow mirrors
- Silencer ring Delete
- Short shifters
- South bend clutch
- Boost
- Do you do anything to the stock Turbo
- cheap Hx 40 options
- Thinking of buyin a set of twins he341/s471??
- Help me figure out what injectors i have??
- trans questions
- Front End Bumpers
- Best place for a pyro
- Stacks or pipe out the back
- am i in trouble
- new turbo to big
- to many miles to bomb?
- hard starting
- Supercharged
- What will these injectors due 140hp
- Suggested programmer/chip
- what to do.
- Clutch Concern
- Thinking of adding an aux fan. Push or Pull?
- Superchips question
- Stock fuel pump removal??
- Low pressure light
- BHAF
- Air Intake Manifold Poll
- intake manifold
- just wondering
- Block Machining
- Cheap bumpers?!
- smarty s03
- injectors
- Bad gas mileage ?
- max injector size for stock vp-44 ?
- 2.5 Leveling Kit Installed W/285's
- P Pump Conversion
- p-pump conversion
- quad adrenaline
- Edge Insight CTS
- ARP PROBLEMS!!
- Stacks on a Regular Cab?
- chips
- T.A.G???
- Help!
- Headlight retrofit w/FXR projectors and 5K HID
- Where to start?!?
- high idle-APPS?
- dont know where to go gauge issue
- tranny swap
- exhaust drone
- 2nd to 3rd gen track bar conversion
- head job
- New Turbo Questions
- BD or quadzilla boost fooler?
- Tst powermax
- Programmer and Tuner Question
- What are your Low Boost levels and why?
- D-Tech Turbos
- tq converter
- fuel pump...
- Whats the difference between Edge Comp vs EJWA
- Thoughts on swaping turbos
- Airdog
- AFTER MARKET TRANSMISSIONS
- S-03 Smarty
- AirDog question
- A little more smoke?
- 2002 more power
- Lift pump toast?
- fast fass help!
- I need some help.
- what's this code.
- anyone getting ready to build a trans?
- Questioning the rational for aftermarket air intake
- Adrenaline, kind of let down
- htt exhaust manifold
- Check out my Leveling kit!
- spare tire in way of exhaust
- air dog ?
- EGT still high...
- Stuck injector
- Woohoo!
- boost controller vs. waste gate jhook
- New exhaust?
- Turbo Up grade??????
- adrenilin problms
- moog ball joints
- wiring harness for edge w/attitude hook up to fass fuel
- Fass 150 titanium
- Turbo upgrade question? hx35/40 hybrid
- Edge Comp box
- Which air filter?
- Who has a P pumped 24v?
- New to the diesel world, just bought a modded rolled 24v 2500
- Info on Air Dog 100
- Transmisssion weak points
- what size injectors?
- What Turbo Should I Get
- Difference between injectors
- wiring two egt gauges together?
- the throttel,key reset thing????
- turbo build up
- Injectors, fuel milage, building for the future?
- Boost elbow
- industrial turbo applications?
- New but wanted to introduce and give praise
- Edge/Smarty Stack
- Injector swap, now hard start
- SMARTY Settings
- NV4500 5th gear clutch ring upgrde?
- best leveling/lift kit
- BD-Power Performance Elbow Orifice
- Connector Tubes
- edge comp
- Smarty programmer COMM TIME OUT ERROR
- question on different programmer n chip setup
- suncoast or goerend?
- oversized injection lines
- Edge Comp fuel economy?
- adjusting quadzilla for best fuel mileage
- Loosing boost
- raptor or should i go bigger?
- quad or edge???
- vp44 upgades and the quadzilla adreniline
- Horse power guess...
- What mods??
- What fittings?
- glowshift gauges???
- Trans Dilemma
- remote start with manual tranny
- question about edge juice
- BD Twin Turbo Kit From SummitRacing.com ??
- Good deal on a set of compounds
- tanny build up
- Redline Box
- free spin?
- Adjust timing to account for different Cetane ratings & fuel mixtures?
- raptor fuel pump and lines?
- is the raptor 150 ok pump?
- 2 cycle oil?
- HX40 Swap
- 2 weeks after new lift pump got a 230 code
- s 300 turbo info?
- exhaust
- quadzilla xzt+
- Guys With the Quadzilla adrenaline i need ur help
- Adrenaline/Pulse Tunes -any suggestions
- torque converter lock switch?
- Turbo go boom!!
- PPE lift pump
- 47re planetary upgrade?
- hy55v specs?
- What tuner?
- 24v to 12v swap?
- Exhaust housing swap
- powermax 3
- turbo parts
- deconstruction has begun
- ATS Co-Pilot or TS Performance TC Lockup
- Need some advice
- Hot Unlock-hot or not?
- best injector
- 2001 cummins
- Swapping back plates on a turbo
- Quadzilla I quad question
- Adrenaline Tunes?
- OVERSIZED LINES!!!!!
- Little VP44 Info
- minor mods
- P-Pump 24 valve?
- Comp
- want more
- multiple 24v problems
- quad adrenaline tunes?
- compound turbo ideas
- what injectors?
- mechanical fuel gauge? what to do with it
- Air Bag Suspension...
- flow max..wow 470.00$$/choices??
- best programmer for a $400-$500 budget?
- DTT trans question
- I Just Bought BD 150 horse injector nozzles
- 24v p-pump
- Boost Elbow
- new turbo higher egts
- Smarty Fuel Economy?
- Opinion on air filter...BHAF or AFE
- Edge comp chip??
- BHAF part #
- EDGE JUICE W/ATT NO BOOST
- rearend upgrades
- propane yes... or no?
- CAI suggestions?
- fuel pump problems
- To get a fuel pressure gauge, or not to get a fuel pressure gauge?
- Opinion on Blue chip FMS
- Quadzilla Adrenaline! HOLY CRAP YES!!!
- quadzilla updates
- 5" exhaust
- diablo sport power puck
- airdog install
- superchips tuner
- EJWA Wiring Harness
- Leveling kit
- Turbo Upgrade
- Adrenaline/Iquad
- Quadzilla Trans Temp
- Fuel Pressure Gauge Electrical or Mechanical
- EXHAUST
- Southbend clutch questions
- best chip
- boost elbow
- oversize fuel lines
- Fuel pressure gauge, needed or not?
- Best "bang for the buck" Mods??
- Trans Choices
- Quadzilla tunes
