View Full Version : 5.9L 24V Performance
Pages :
6]
8
9
10
11
12
- Different Ideas for an Air Filter, Opinions Please!
- What upgrade next?
- injection pump?
- SDX injectors
- Injector nozzles
- exhaust brake
- Tuning the ECU
- Fuel pump issues
- injectors??
- Turbo
- Tranny Cooler Lines
- vulcan draw straw what is it how does it help
- Edge comp or EJWA
- Tranny Swap
- Anyone with Aftermarket Intake Manifold?
- 98.5 Twin Turbo Upgrade
- CB mounting in '01?
- Marine 370 injectors
- Mod Advice
- HY35 Compound setup
- 7x10 injector..
- Smarty Question
- quadzilla pump stretch question
- New stuff, Quad and Airdog
- my chip dont work
- fuel pump
- Injectors
- Installing Fuel pressure gauge
- Transmission question
- Quadzilla Update problem
- 4" vs. 5" exhaust system
- EJWA wiring harness
- Air bag suspension
- More Power!
- psc steering box
- New fuel system
- turbo numbers on ht60
- Gauge question/Boost question
- 01 to 99 EJWA swap
- Getting Rid of Banjos
- chip or no?!?!
- surging,jerking
- What injectors,programmer,turbo how does it smoke and how about the egt?
- tuner/Programmer guage first then tunes/programs
- Don't know what air filter get...
- edge juice cs or cts
- kore leveling springs
- Can't find spot to Install trans temp sender on 2001 Dodge Ram 6 spd manual!
- Towing on "fuel mileage" setting?
- Needing HX-40 Info.
- p-pump conversion
- Adrenaline problem. Help?
- Accel power box?
- help banks ottomind
- Extra lift pump?
- quadzilla boost fooler or dr performance module
- edge jammer injectors? any good?
- TST & possible wire tap or Boost issues?
- stacking chips making power
- Tranny upgrade
- superchips
- Fuel Filter system
- CRANKCASE BOTTLE RELOCATOR KIT
- ?smoke switch?
- help clutch
- Small issue with Adrenaline
- BD PressureLoc. Anyone tried it??
- Adrenaline cuttin truck at 90mph
- Exhaust brake!
- BONE stock 02 cummins just purchased only 48K on it
- h1c/hx35 twins
- h1c/hx35 twins
- classic hp question guessin
- Aluminum Head
- Need Help!!!
- module stack
- stackin
- DR PERFORMANCE DEAD PEDAL
- AD 150 parts
- tranny question
- Boost fooler
- how smart is a smarty?
- BOOST PROBLEM
- what to do??
- Quad Questions
- 2001 dodge
- P pump conversion
- Convert to a p pump?
- hids hig and low beams?
- smarty with a edge EZ
- looking for a MITUSA Pump
- stiffer valve spring disadvantages??
- edge comp or quadzilla
- Just died after acceleration
- Smarty or bigger turbo?
- Intake horn
- Quadzilla Adrenaline questions
- DIFFERENTIAL COVER
- Southbend clutch installed now cant shift
- Intercoolers
- New box coming out for 24vs 98 to 01
- Exaust noise stock vs aftermarcket.
- Quadzilla XZT plus
- Transmission upgrade
- 98-02 Dodge Ram 2500 4x4 Dual Steering Stabilizer Kit with Bilstein Cylinders
- Programmers/chips - So many to chose from!!!
- update ECM to monitor EGT, boost, fuel pressure?
- fuel pressure gauge problem
- Clutch
- Best fuel pressure gauge
- pulse buttons
- quick question
- Bosch 300hp marine injectors
- What size injectors to go with a super b special?
- clutch question
- Turbo Question
- 2001 Cummins. Best chip/module?
- Drilling manifold for pyro
- Smarty, Edge Comp, OR Edge Juice?
- Smarty Edge Stack??
- new turbo
- chip
- TS Performance MVP Module
- Super b special how will it work with auto?
- headlight mod
- Nobody seems to have an answer please help!!!!!!!
- edge cs or cts??
- water pump
- Fuel System Upgrade!!!!
- Airdog II 165 New Quick Connector question
- Fuel Filter Relocation
- changing trans fluid this weekend
- Where to go from here.... Turbo? Injectors? Which ones?
- VP44 out the door
- how will this turbo work
- B&M Trans Pan
- Cummins 24 valve upgrades on the cheap?
- Turning up fuel pump
- Autometer Lite Fuel & Oil Pressure Guages
- Super B Special wastegate
- Got an idea need some help
- Home made w/m injection
- To pump or not to pump......
- Nitros
- FASS 95 FILTER FIX !!
- exhaust brake
- turbo suggestion for towing
- 175's or ADR?
- Simple Edge EZ question.
- towing mirrors?
- exhaust manifold
- fuel pressure reference
- new Raptor 150 & drawstraw leaking fuel?
- fass ddrp lift pump pressure.
- etreme suspensions DC 6" long arm lift? reviews?
- nv5600 to 47rh
- plug and play
- Heated Mirrors
- headlights
- Wrong Turbo ?
- 98-99 hd steering upgrade
- Boost fooler on 99 24 v.
- P pump
- AirDog II 165 problems
- my free boost
- Oil Pressure Guage
- What turbo should i get??
- HT3B
- oil feed line
- Braided line
- Bilstein Shocks.
- oil to turbo question
- pumps ????
- exhaust brake?
- map sensor question
- Wanting to build a set of twins
- Where to buy BHAF
- fuel pump light on dash.
- What size injectors?
- fire ringing
- compound setup
- Injectors or Nozzles
- FASS v AirDog
- swapping input shafts
- some air dog issues (any idea?)
- Timing
- Electric fans
- Banks stuff on a 00
- HX35/40 Hybrid?
- cng?
- holly blue electric
- FINALLY!! New Twins
- Valair Clutches
- electric blue fuel pump.
- torque loc switch
- Stacking
- Bomb-proof bolt on 2nd gen steering! Cheap!
- Will not build boost with trailer?
- good looking grilles
- Low cost upgrades?
- Airdog 100/150?
- seats
- 64/?/14 turbo
- Raptor 100
- fuel pressure question
- juice vs adrenaline?
- i need advice
- Edge Juice w/Att A/C Vent mount mod
- 13:1 Compression Raito VP44
- how would a super b work for me
- FASS 150 troubles
- Raptor Dead!
- QC SB Air Dog mounting
- waste gate question
- Used Airdog 165
- FASS
- Oil breather canister
- P Pump
- way to fast
- Monster Pumps
- what mod should i do next
- Fuel Pressure Gauge Install
- p-pump swap
- Tire sizes/mph
- Liberty Fuel Module W/ Draw straw
- HX35 and HT3B
- HEAD STUD INSTALL
- FP Gauge
- i got new gauges
- What turbo?
- header for sale on craigslist
- ok all you adrenaline users looking for best tune for drag strip
- quadzilla pulse tuning
- cheap mods for turning up a 24valve?
- turbo rebuild problem
- FASS DDRP-02 Lift Pump ?
- What next??
- RAPTOR 150 PSI
- Tell me what turbo to run
- silverline stack kit
- aftermarket intakes, worth it or not
- b&w hitch install
- cummins upgrades
- twin tube connectors?
- Where can I buy a southbend Clutch kit And Inputshaft for NV4500? Broke it today:(
- super b or hx35 +ht60 =twins
- Smarty Updates
- edge juice/Quadzilla drenaline
- diffrent setup... turbo question
- How do you reset the apps sensor?
