PDA
View Full Version : 5.9L CR Performance
Pages : 1 2 [3] 4 5 6
  1. diablo predator on 04.5 cummins?
  2. Banks intake with a dry filter?
  3. Volant CAI
  4. What size tire will fit
  5. wow, so many mods possible?
  6. Free Spin Kit from Dynaloc
  7. Looking for a new turbo
  8. 04 Smoke Switch?
  9. Power Puck Junk!!!
  10. smarty tnt
  11. injector lines.
  12. turbo question
  13. school me on turbos please
  14. stacking programmers on my 2003 cummins
  15. EDGE CTS Thoughts??
  16. Bracket Pic
  17. mod help please for 03 cummins ho
  18. upgrade help 03 cummins
  19. which one
  20. 500 hp what's it take to get there?
  21. Dodge Upgrade questions
  22. WHATS A GOOD STACK FOR MY 04?
  23. any more word on efi live?
  24. Halo headlights. Y'all like?
  25. Quadzilla boost fooler?
  26. Stacking with a Superchip?
  27. ford lockouts?
  28. DIY CP3 mod GO or NO GO
  29. Got my Smarty today
  30. new tires
  31. Tsd
  32. help please: ts shift master
  33. Quadzilla Xzillaraider and gauges?
  34. Getting ready to install a pro 52.
  35. new turbo question?
  36. Steerng box brace.
  37. how to make a 03 cummins lope
  38. What is a good set of Twin on a 3rd gen
  39. HOw much shaft play is acceptable?
  40. Quadzilla xzillaraider2
  41. which programmer
  42. gauges??
  43. change the nozzles yourself bd-power injector nozzle
  44. 06 and 07 guys rejoice efi live is on its way
  45. 6.7 turbo in a 5.9
  46. jia mu turbo?
  47. 2 cycle oil
  48. PROGRAMMING CHIPS FOR CUMMINS
  49. Diablo Sport Predator tuner
  50. Bit the bullet
  51. no start after airdog install
  52. Want to Kill Drone
  53. injectors and lift pump
  54. Need help with TWINS
  55. D-62 Turbo any good?
  56. Do's & Donts on tranny rebuild
  57. Stacking with a Banks Bullet to get improved mpg?
  58. o5 raptor 150 install, broke down and got questions
  59. Best Gauges For My 06?
  60. which injectors should i get for 03 5.9l?
  61. Smarty Or Edge??
  62. Have Edge now, get Smarty instead ??
  63. Air Dog Problem
  64. new clutch, any suggestions
  65. Need help with my SMARTY S-06
  66. Check out this manifold!
  67. Tank pressure?
  68. Custom Dodge Emblem
  69. This Mod...Yes...No?? Status Update
  70. Leveling kits
  71. Dr performance stacked with Hypertech programmer
  72. airdog or fass???
  73. Lookin to buld my tranny in the Summer
  74. Could use advice on exhaust and intake...
  75. Smarty REVO
  76. EGT Question
  77. Injector
  78. exhaust
  79. Smarty Jr. Software versions
  80. Valve bodies
  81. boost gauge
  82. Cummins Exhaust (Cat/Muffler Delete)
  83. Which CP3 pump to use?
  84. stacking a PPE xcelerator and MP8
  85. HELP INJECTOR
  86. cold air intakes
  87. programers
  88. South Bend Dual Disk
  89. Smarty Lope Coming
  90. Banjo Bolt on a 2007 Cummins fuel canister intake line.
  91. Header / exhaust manifold ?
  92. Air Dog Question...
  93. Turbo exhaust wheel ?
  94. BAE Operations Exhaust Manifold
  95. how do you stack chips?
  96. Gauge/Pillar Set
  97. MBRP Disappointment :(
  98. ATS G56
  99. New Cummins Owner
  100. BD Injector Nozzles for Common Rail Cummins
  101. BD Diesel Injector Nozzles for CR Cummins
  102. CalTracs Traction Bars
  103. School me on T/C controllers
  104. Bullydog PMT question
  105. black smoke and power
  106. Cp3 buzzing??
  107. Super Rail Feed
  108. suspension lifts
  109. Quadzilla Adrenaline w/ P2
  110. i just bought 07 cummins 5.9L have questions...
  111. Quadzilla Adrenaline Setting for Stock '06 W/ Auto
  112. need some ideas
  113. what to stack
  114. Bigger Injectors
  115. What kind of chip should I use?
  116. Need help selecting a turbo(s)
  117. bully dog question
  118. School Me On Rail Pressure Gauges
  119. Problems with ATS diesel
  120. Stacking Advice
  121. 0-60 times
  122. Injectors 03/04
  123. been runnin a 66 for a couple weeks...my thoughts
  124. 6.7 parts on a 5.9
  125. New crazy larry
  126. New truck help?
  127. Banks Big Head for cummins
  128. ZF6 swap
  129. Built Transmission w/TC
  130. Question about Programmer
  131. Whats Next?
  132. turbo
  133. My 'Selecable' Muffler Install (w/ Pics)
  134. Best way to make smoke?
  135. Injectors
  136. ATS 5000 Turbo on Diesel Power Source Twins?
  137. MADS Smarty Sr & Jr Owners
  138. Bullydog Triple Dog
  139. crazy larry
  140. S400 74/74/AR1 / Stock , Twin setup?
  141. Fried Goerend Transmission
  142. FCA question
  143. Really stupid question about edge juice
  144. on a 04.5 what is the stock torque converter stall rpm????
  145. the ballvalve on the heater hose is that ok to do ?
  146. Intercooler upgrade Common rail
  147. SMARTY Programmer
  148. Industrial Injection cp3 Bag Of Parts
  149. Fuel Pump Upgrade
  150. torque converter low stall how low to go?for towing some help please
  151. smarty tuning help
  152. trans is acting up help?
  153. valve body witch brand and why? what is the diffrents
  154. Transmission Build
  155. trans goerend valve body install do need to drop the trans
  156. dr p and smarty...
  157. turbo question?
  158. Bigger injectors or better chip
  159. Airdog helppppppp
  160. Torque Converter selection
  161. Anyone Have a Pricol Optix Fuel Pressure Gauge Wire Diagram?
  162. exhaust brake
  163. turbo upgrade?
  164. jake brake help !!!!!
  165. smarty 4.2 betta
  166. lighting a big single
  167. hi
  168. Coolant Bypass Kit
  169. I got a SMARTY today
  170. fuel pressure on my 03
  171. Remote 48RE trans filter kit
  172. Boost Head Studs
  173. Airdog Install Question
  174. turbos
  175. Airdog Advice
  176. Smarty Jr. Tuned for MPG
  177. Bilstein shocks?
  178. HELP New Turbo waste gate ?
  179. Some of the least smokey upgrade injectors
  180. rank top 3 for nozzles, CR power and customer service
  181. Explain the Smarty Jr (J-06) settings to me...
  182. HID's
  183. New Turbo showed up today
  184. HOW TO: Headlight swap, by spike7ss
  185. bullydog triple dog issues....
  186. JASPER Transmisions ??
  187. Turbo swap?
  188. best progammer/chip??
  189. Sorta EMERGENCY! 03 versus 05 turbo??
  190. drive pressure??
  191. Alright, lets see those bush bumpers!
  192. BULLY DOG AND QUADZILLA ADRENALINE
  193. coil spacers?
  194. Airaid filters
  195. Muffler Delete or full turbo back?
  196. air intake 05 cummins
  197. Glacier 2 Micron F/W Separator Combo or ???
  198. Modding smarter...
  199. Smoke switch?
  200. homade exhaust question
  201. just a random question
  202. 5.9 camshaft - egr
  203. smoke switch
  204. How much boost before studs?
  205. Gauge Install
  206. Adding a programmer with stock trans?
  207. phat shaft 62 vs factory turbo = big difference in mpg?
  208. Blowin Smoke
  209. Advice?
  210. boost fooling help
  211. Best Intake for turbo noise?
  212. 04 common rail chip ?'s
  213. turbo help
  214. turbo boost control elbow...
  215. Edge Juice w/ Attitude explained
  216. installing a 2nd gen intake manifold
  217. installing southbend dd
  218. brake pads stock or aftermarket?
  219. raptor pump install
  220. Need Some Anwers From The Pros
  221. Smarty setting for mpg???
  222. Wicked Diesel
  223. air lift 5000 or firestone ride rite pics
  224. TRANS TEMP QUESTION
  225. Mag-Hytec front diff cover
  226. Air dog
  227. Bully Dog Question
  228. cummins turbo question
  229. HTT 62/65/12 Turbo For A 2006 Dodge Cummins
  230. Twins?
  231. needing turbo help!!!!
  232. how to make 600hp
  233. Way to stand behind your products ATS,NOT!!
  234. Tuning!
  235. injector tips
  236. Running Nitros
  237. Train Horns Done Differently
  238. Turbo experts can ya help me.
  239. injectors and arsonIII
  240. towing twins
  241. how would you spend $3500?
  242. bd steering stablizer?
  243. down pipe
  244. Input on injectors and what to stack on top of my 6 Gun
  245. 35 inch tires with leveling kit
  246. Bully Dog Triple Dog
  247. Added some power..first mods
  248. 2004 3500 Cummins "Shaking"
  249. TST or smarty
  250. Water/Methanol Injection
