PDA
View Full Version : 5.9L CR Performance
Pages : 1 2 3 [4] 5 6
  1. Water/Methanol Injection
  2. I love this thread system....
  3. Hot unlock for Edge.
  4. Looking for increased acceleration
  5. winter prep
  6. pics bull hauller stacks
  7. Still no smoke! WTF!
  8. Edge Juice
  9. Expandit Exhaust
  10. Quadzilla help
  11. Injector time! :argh:
  12. whats the best way to spend 7500 bucks
  13. Smarty stack?????
  14. Gauges not working!!!
  15. 6.7 pistons in a 5.9
  16. Mbrp dual exhuast.
  17. HTT JUNK!!!!
  18. boost elbow should you put a aftermaket on?
  19. what should the 4 gauge be??rail or fuel pressure
  20. Am I asking for problems?
  21. boost gauge pulse
  22. auto meter placement?over mirror? piller?under radio?
  23. Opinions on transmissions
  24. Bullydog w/ smarty??
  25. on the new air dog 2 used with out an in tank pump
  26. smarty can it read code on ford ,chev ???
  27. lift pump in tank do you have to drop the tank to add fuss or air dog ???
  28. WITCH SHOCK WILL RIDE BEST RANCHO OR BILSTEEN
  29. IF YOUR LIFT PUMP QUITS AND YOU GO WITH ATFERMARKET
  30. Turbo shoppin
  31. thinking of putting injector tips 50 hp should i ?
  32. guage wiring for 3rd gen cummins?
  33. 5" Stainless system for 2006 5.9 What Brand?
  34. THE WILSON THRASHER INTAKE MANIFOLD HORN
  35. SHOCKS FOR A 3500 DRW HEAVY PAYLOAD ??
  36. Vulcan Draw Straw
  37. Edge juice with attitude
  38. Bully Dog
  39. HAS ANY BODY USED S&B INTKE NORN???
  40. High egts on stock truck!?!?!?
  41. Has anyone heard of these guys?
  42. SWANK INTAKE HORN HOW GOOD???
  43. stock intake manifold or aftermarket? with stock turbo?
  44. smoke switch install on 05 with edge juice
  45. STOCK INTAKE MANIFOLD OR AFTERMARKET ARE GAINS REAL??
  46. Intake ?
  47. GOEREND OR B&D TRANS ? TC. VB.?WHO BETTER
  48. NEED A NEW TRANSMISSON ?WHAT BRAND??
  49. marine injectors for the common rail????
  50. Tuner vs transmisson
  51. WATER AND METH INJECT BEST ONE FOR MPG???
  52. HEAD STUDS WHEN SHOULD MOD THEM???
  53. ladder bars
  54. WATER AND METH INJECTION HELP S WHAT ??
  55. SMARTY 06POD OR SMARTY JR???
  56. lift kit need help asap
  57. MPG WHAT IS THE BEST PROGRAMER/04.5
  58. Quadzilla Adrenaline CR Experience
  59. New exhaust recommendations?
  60. 06 cummins exhaust manifold
  61. Chips and programers
  62. ts shift master?
  63. NEED OPINIONS ON US DIESEL MODULE LOOKING FOR MORE MPG?
  64. what programer
  65. EGR PLATE TO MIA HOW TO HELP NEEDED?
  66. Best mounting spot for Water/Meth injection
  67. Smarty question for BOB "CA Users"
  68. DT Profab track bar
  69. 2003 Turbo
  70. 04.5-07 Injectors
  71. nitrous propane or water/meth?
  72. Smarty jr will be here Fri. now i got ????
  73. How important is air removal?
  74. Torque and Trannyt qs
  75. Head studs
  76. 48re question
  77. air dog
  78. Injectors and clutch
  79. Stack Size
  80. Whats the best tunner for 04 dodge 2500??
  81. Attitude VS Adrenaline????
  82. Easy (inexpensive) wheel hop / axle wrap fix?
  83. FASS Platnum finally installed!!!
  84. ummm what the......
  85. HOW TO BETTER MPG
  86. Best stacking?
  87. Air Filters
  88. larger exhaust
  89. muffler
  90. Fass install location?
  91. Installed a airdog
  92. Which Clutch
  93. guages
  94. TST PowermaxCR with R49
  95. guages
  96. NV273 Question
  97. boost fooler
  98. Hood stack?
  99. Best mileage chip/programmer?? 07 5.9L
  100. Dually Lift
  101. billet input shaft
  102. EGT gauge problems
  103. Boost and EGT's
  104. Smarty Or Edge ?
  105. How to build the 48re
  106. fuel pressure gauge problem
  107. What's it take for 13s
  108. Brand New Bullydog PMT in an '03 Dodge 2500!!!!!
  109. CRAZY LARRY with a BULLYDOG PMT....???
  110. Looking to upgrade Injectors... suggestions... experiences?
  111. Smarty???
  112. questions
  113. If it was your 48RE...
  114. Nozzle MPG's?
  115. Chip?
  116. Smarty TNT Revo download...oops
  117. transmission and tire?
  118. PPE or Smarty?
  119. Ppe programmer
  120. Smarty Jr Installed
  121. banks 6gun with pda or diablo trinity?
  122. Fuel Economy with the Smarty Jr
  123. boost?
  124. A Different Take on Traction Bars
  125. Boost Fooler helping 48RE?!?
  126. tech mod question
  127. Water Pump
  128. Banks exhaust break
  129. opinions on Bully Dog programs
  130. More Power Dodge Ram 2004
  131. 05 3500
  132. Turbo ID help
  133. Version Of EFI Live
  134. isspro boost install
  135. WHAT SHOULD I DO??
  136. Smart setting.
  137. Has anyone tried this?
  138. Egt drop expect from Twin set up?
  139. exhaust?
  140. Has anyone herd of using grade 10 allenhead studs instead of head studs?
  141. an incredibly bitter sweet xmas gift
  142. Does this seem right?
  143. vp44
  144. In need of some help/advice...
  145. Need some FASS answers
  146. timing That is the question!
  147. Smarty tuning help and egt's question
  148. rebuild time
  149. Why wont my truck smoke
  150. 4 in downpipe
  151. Billet input
  152. horsepower options
  153. goodies on the way
  154. New to CR's
  155. Recommendations on a programmer needed
  156. what chip
  157. stacking question
  158. New...looking for best Cummins to build
  159. Cold air intake
  160. turbo questions
  161. Trans -go shift kit?
  162. will it work
  163. Urgent Help with Banks six gun and IQ!!
  164. clutch and tranny help
  165. transmission and clutch help
  166. Changing muffler on stock exhaust
  167. Banks IQ
  168. which one?
  169. Airdog II Install Questions
  170. Torque converter / valve body issues
  171. stacking
  172. HID headlight problems
  173. Revmax Torque Converter
  174. Common Rail Help
  175. Any DOWN SIDE to an Air Dog 100?
  176. Cooling Mods to keep Cyls 5 & 6 cooler?
  177. Exhaust Systems
  178. Starting a street rod project
  179. Bully Dog Watch Dog, or Predator Trinity????
  180. Smarty on 03 S.O.
  181. WHATS THE BEST??
  182. what to do next?
  183. Retiming the CP3 To TDC
  184. anyone have a raptor 150?
  185. Engine Oil Bypas Filter
  186. bullydog possible stack ????'s
  187. Tips and tricks to increase fuel economy?
  188. got my smarty in today!
  189. pics of lifts and stacks
  190. Outlook monitor keeps freezing up on startup
  191. Edge Juice w/ Attitude monitor problems
  192. Battery Quick Disconnect
  193. Air dog help
  194. Second half of To build or not to build.
  195. Build or not to Build:That is the question
  196. Where to find pistons for cummins
  197. PPE tuner question
  198. cummins smoke
  199. air dog quits....turn off key and back on it will come back on?...
  200. Crazy Larry
  201. Turbo upgrade for 03 S.O.
  202. Issue with My edge Juice w/attitude
  203. Fuel pressure guage install
  204. 03 cummins injector and cp3 question
  205. Trading for a dodge
  206. programmer
  207. 5" dual exhaust
  208. Bully Dog GT
  209. 3rd injection event removal?
  210. auto to manual swap
  211. converter and valve body
  212. Got a new truck!!
  213. Wanting the best setup for mpg and power if needed
  214. BHAF on 03'
  215. Head Studs,Turbo, and Divorce celebration!
  216. UPDATE on Need your expertise!
  217. Fuel pressure ?
  218. exhaust brake question
  219. fass pump
  220. ADVICE: BEST CHIP/DOWNLOADER??
  221. cheap, or free mods
  222. Tuning my 07 5.9
  223. hdfiremedic
  224. Used Smarty Question
  225. 12v lighting for gages
  226. 3rd Gen Tech Write up list
  227. Upgrading mirrors
  228. Torque converter lock up switch
  229. Diesel Nut transmission rebuilds?
  230. Power increasing products
  231. CR ?
  232. MP-8?
  233. Air Intake Mistake?
  234. Anybody actually know anything about turbo setups?
  235. Holset Turbo... HELP!
  236. Smarty for the 5.9
  237. how to install boost, trans. and pyro gauges in a '06
  238. 4" or 5"?
  239. Using turbo from 06 on a 12v???
  240. New Smarty S06 PoD REVO-TNT software available
  241. Bye bye cat
  242. Smarty Jr Vs Sr
  243. Stacking chip/programmer
  244. Edge Juice W/Attitude problems?
  245. should i external wastegate
  246. Leveling Kit
  247. Edge Juice w/Attitude
  248. Smarty Half Power
  249. what stacks good with JR
  250. need help asap installing this turbo
