- Smarty Trace
- Looking to Lower
- just a little more...
- Multiple fuel tanks
- Aftermarket elbow
- boost tube
- best cold air intake?
- Road armor front bumper
- studs
- Diesel Greenhorn
- tuners? which one for my truck
- engine install problems need help
- how do you install a smoke switch on a 6.7 cummins
- H&S Blackmaxx question
- Smarty Jr
- H&S XRT
- Diesel Mod Shop - Manhattan, KS
- Bigger Injectors, What Other Mods Do I Need ??
- Advise on new Torque Converter
- Funny noise?
- dpf egr deletes
- Any dually's out there?
- New Intake Horn
- '08 Deleted last night!
- Mini Maxx Question
- smarty problems
- Quick Question
- Edge Juice + DPF Delete?
- 2011 delete
- Smarty jr for dodge 6.7..... wont smoke!!!!!!!
- Stock Turbo and hp
- Need opinion on Airdog 150
- will they fit?
- 6.7 exhaust
- EGR cooler
- Airdog II
- dpf delete without tuner?
- What to do?
- Upgrading
- 2010 smoke switch
- Black Ops Diesel
- H&S
- Need some Stacking Advice.
- S & B dry or oiled filter?
- Dr. Performance
- Edge Insight
- CEL light with mini max
- DPF delete question
- Xrt question
- Need Help!
- xrt
- Cold air intake?
- Lazarsmith
- Installed mini max and 5"turbo back exh!!!
- FINNALY BOMBED
- Injectors
- Tip question.
- Cheapest Flo Pro
- smoke
- H&S XRT with "0" is no longer useable?
- xx-fuel, airdog, fass
- Programmers
- Mods with automatic Tranny?
- MINI MAXX LESS THAN $950? Anyone cheaper? Taking bids!
- Biggest Tires with Stock ride height?
- any advise
- finally bobmbing need advice
- 09 6.7 tuner info
- DPF delete and the check engine lights comes on
- DPF delete kit help
- 6.7 tranny
- exhaust
- Head Gasket leak - I'm going to BOMB it.
- 08 6.7 egr/ chip questions
- cummins 6.7
- boost gauge install
- Programming smarty while edge is on?
- Straight Pipe-Power and Fuel Economy Gain?
- 6.7 Build
- H&S Performance Intake Elbow Install
- Maxx Flow Intake
- Quadzilla Adrenaline
- H&S tuner
- butterfly valve
- Need some advice
- coolant
- Arson Jr. II
- Is a EGR delete necessary?
- Throttle Valve delete
- need advice
- What can the dealer see about tuners
- Question about Quadzilla Boost Foolers?
- Where to go??
- 6.7 Edge/Smarty Stack
- whats a safe egt for the 6.7
- fuel mileage
- 6 speed manual noise
- 2009 Just deleted
- DPF & EGR Stealth Removal Theory Questions
- s67 smarty
- 4-09 build date and programmer
- Guages
- tranny oil?
- in need of a used DPF
- Bluetec Exhaust after delete
- Excessive smoke
- DPF deleted but have some questions.
- Black Max vs. Mini Max
- fun in my cummins
- 6.7L Stock Pistons Vs Coated 6.7L Industrial Pistons
- need lots of help
- Smoke Switch
- Installed AFE filter
- Flexalite Fan
- 22.5 wheel and adpater removal - tech advice please
- Programmer
- bunch of codes
- any HP/torque increase?
- common rail heads
- Time Frame to remove the DPF
- need advice dpf delete
- can a smoke switch be used on 6.7 with stock exhast?
- Crazy Larry 2.3.2
- h&s tcm tune results
- Cummins 6.7 deleting
- 2008 Cummins 6.7 Deleting
- Edge vs Smarty and guages
- a new 6.7
- Finally got my wheels and tires
- 6.7 turbo - need help
- 07 6.7L Dpf w/o tuner
- Help with exhaust eliminator
- Best exhaust for the 6.7
- exhaust
- HID Lights
- how do I get my truck to smoke more
- question for guys with grid heater deletes
- The Agony of Defeat
- Upgrades Installed
- DPF DELETE
- JUST MY LUCK
- sb 3600 dd help
- 6.7 Tuners
- Gauges
- What to do?
- Finally dynoed with the silver bullet
- Programmer Questions
- New MINI MAXX from H&S
- 6.7-5.9 head swap ??
- 6.7 cummin heating up or over heating
- 6.7 with DPF removed and a smarty - setting invisible code
- g56 swapped with NV5600
- more power from the 6.7
- 4" or 5" exhaust?
- anybody seen this kit
- 22.5 wheel recommendation - need a little help
- Black Maxx and codes
- Delete Kits
- 2cummins
- Next Mod
- Shaker hood????
- Superchip Info Please - DPF Delete?
- Smarty jr can it
- P Pumped 6.7
- S&B air filter recharging
- Exhaust Disappointment
- Dpf And egr removal??
- DPF Delete
- Why Codes???
- 6.7 forged rods?
- Advice from the smart people here
- Transmission 68RFE Broke need alternative
- Can you?
- EGR deleat?
- Programmer or chips.
- questions about turning up a 6.7
- Smarty JR
- smarty with shuddering shift
- injectors
- Anyone done a dpf and egr delete with no programmer?
- H&S Blackmaxx
- 5.9 swap
- Do I need to upgrade further?
- Any advice for clearance light install?
- egr and dpf delete kit
- Dual Disc?
- sim
- black maxx with air dog or fass??
- Cab Light Install Template
- Tricking the Computer
- Smarty advice
- after market radio helppp
- black maxx question
- Smarty jr
- new turbo
- Time to make a real truck.
- Black Maxx ?
- egt temps with edge juice
- what are sims for pyro probes?
- can you hollow out the dpf?
- Edge race Juice
- do bully dog progrm.leave footprint on ecu?
- 6.7 mods advice
- 6.7L ME Dodge Smarty Junior.
- cp eclipse downloader
- H&S Blackmaxx?
- airdog 200
- LoveFab compound turbos
- is anyone on here running this twin turbo kit???
- Programmer
- are there any mods that can be done to the 6.7 and not void the warranty?
- twin disk clutch question
- Chassis Cab Smarty
- Couple questions
- Best dpf delete kit????
- Bully Dog Cracks The Code..
- black maxx installed
- Another smarty question
- Hollowing out the dpf?
- smarty
- Clutch vs Black Maxx
- Info please on 6.7
- Black smoke with DPF????
- Black Maxx
- Down pipe catalyst
- H&S Update
- Bomb Time For MEGALONGBED
- afe cold air intake
- Edge Juice with attitude
- TS Power Play MP-8...opinions?
- Bomb time!
- EGR Delete Question
- Cummins mods
- xrt-smarty on the dyno
- which programmer???
- S&B intake install and review.
- 2007.5 3500+ Bully Dog PMT = Possible Buyers' Remorse
- EGR & DPF Deletes
- What is needed
- 2009 Egr cooler deletes
- EGR Delete
- Banks Cold air intake?
- Anybody running 15ME yet?
- smarty question???
- k/n drop-in?
- Smarty 6.7 ME Update
- new Smarty V15 ME question
- Looking for CAI
- Technical Details of EGR and Turbo
- hx40 turbo????????
