- 92 F350 transmission
- truck is surging
- whats it worth
- Aftermarket Tachometer Question
- 1985 f250 6.9 problems
- 93 7.3 turbo- developed miss and other noise
- 7.3 idi dies under a load.
- 86 F350 6.9 questions
- oil leakage 1 gallon a day
- Is it safe to bore a 7.3 1990 .030 over?
- e4od transmission problem
- Glow plugs not getting hot
- need 80-86 truck body parts
- Ford Deuce Roadster
- 85 rear tank not working
- help with ip on 7.3 idi turbo
- 6.9 running great (fuel cutoff in top of pump)
- Heater core bad?
- toy
- need help with injectors
- Front Hub Problems please help!!!
- pro-charger ?
- Fan went into the radiator
- 6.9 f250 85 pickup DIEISEL with MEASELS
- 85 f 250 6.9 no fuel at injectors
- Water pump leaking
- Burning Up Glowplugs
- 6.9 egts
- Knock when first started
- engine will not heat up
- Weird pickup while driving
- Front axle
- Glow plug relay wiring 93 F250 non turbo
- Fuel Filter Changes for dummies?
- '92 7.3 IDI missing/surging gray/blue smoke
- Exhaust
- truck won't start.
- pics of ats turbo hooked up right
- Best battery for the 6.9L?
- Return line
- 91 non turbo 7.3 engine swap ?s
- turbo a 7.3 idi help
- F250 Intrernational 7.3
- exaust size
- 6.9 turbo adjust
- 7.3 in custom explorer any comments?
- funky fuel guage
- 86 f250 6.9 starting but does not stay running
- replacing my cab
- 1992 f250 7.3 wont start
- 7.3 na advise
- 7.3 turbo idi, help please
- HELP PLEASE
- Non Turbo 7.3 advise please!
- owners manual and repair manual
- more power
- Leaky IP
- 1990 IDI what to do with it?
- slow take off
- TEMP. QUESTION
- nothin fancy
- ready to start
- poor throttle response and low power
- custom turbo
- tranny for 88 ford
- timing advance??
- clutch
- ip pump
- 4x4 conversion
- mpg?
- 93 f250
- wieghts and dimensions
- 1992 7.3 diesel bone stock.
- Clutch Adjustment
- Wiring Harness Swap
- E4OD controller
- Shifting Problem? Cab Floors?
- **1985 F250 6.9L EBay listing $2000 start bid
- 1985 CLEAN F250 6.9l for sale $4000 obo
- Won't fire when cranking
- Air conditioning
- My 1992 F350 7.3 powerstroke won't start
- Worth it?
- Rear end info
- Straight Pipe?
- High idle problem
- Racor?
- What can I get for under $5K
- head bolt torque specs
- Borg warner?
- 87 f250 tranny trouble
- 89 7.3l
- Transmission question from a new guy
- 7.3 idi w/banks sidewinder kit
- 87 6.9 questions
- looking for injectors/exhaust
- 85 6.9 sloooooow starting
- Looked at a GPR...WTF!!
- tires
- 85 3/4 6.9 L glow plugs not working??
- need help!!!!IP
- Clicking noise?
- How much oil, additives?
- Exhaust diameter question.
- IDI turbo.
- Fuel Problems with my 6.9!
- How much HP and TQ do you make Turbo-N/A?
- Looking at a 1993 w/turbo.
- 84 f-350 6.9 and 4spd
- ZF 5S-42 Parking Brake Woes
- Turning Up The 7.3 IDI
- My tach 'aint tachin
- 6.9 f350 won`t shut off !!
- Which IDI?
- 7.3 / 6.9 Max driveble hp & tq min $ Tell me what you think.
- f250 to f350
- 7.3 injectors
- EGT gauge on 6.9/7.3?
- Oil Cooler
- Turbo Rebuild Kit???
- what is the differance between the E40D and the 4R100 transmission
- Will Super duty lift fit my 92 f350?
- Where is my coolant sensor?
- help with hood stack on 91 f250 7.3idi
- What do you think? Do I need an intercooler?
- 1990 f-250 7.3 diesel won't start
- 4bt in a 85' f-150
- new project
- Hey Could i get some advise on this?
- 84 6.9L
- size specs
- 7.3L Took a Dump
- Reman engines
- 6.9 navistar problem
- 5-speed to a 6-speed
- Transmission Swap-Auto to Manual
- Can't Start 6.9 liter
- 7.3 help running
- '94 non powerstroke
- 12" CLUTCH UPGRADE 6.9 & T19
- What Can I Do
- Hard To Start Overnight
- Starting Problem
- Injector Removal And Install E-350 Van 7.3 Diesel
- Heavy Duty Headlight Harness
- I NEED HELP
- How Many MPG
- First Upgrades
- Electrical Problem Please Help
- 1993 Ford Turbo Diesel
- need some help!
- 93 F350 Needs An Intercooler
- Testing A Glowplug Relay
- Tested Glowplug Conectors...6 Ohm Good/Bad?
- Turn Up An Injection Pump On An 84 6.9 Diesel
- Low Boost 5psi Max
- 1994 IDI Question
- Missing All The Time
- Looking At A 1986 3/4 Ford Diesel
- My Idea For A Twins Setup On A 7.3
- DT530 Injectors In A 7.3
- 3 Options, What Would You Do...
- Who Says A Turbocharged Mechanical 7.3 Can't Make Power
- 2wd Lift Kit
- Gotta Be The First One!
