PDA
View Full Version : 12 Valve 2nd Gen Dodge Cummins 94-98
Pages : [1] 2 3 4 5 6
  1. dampner and front main
  2. Ball Joints - Moog vs. XRF?
  3. Help!!! wont start !! is the pump fried??
  4. tire issues
  5. more problems!!!
  6. 94 AUTO towing problems
  7. Burnt out fixing the NV4500
  8. Fuel Filter problems
  9. Valair or Southbend?
  10. headlights
  11. Speedo Adjustment
  12. gauge readings
  13. columbus diesel
  14. Some Good Reading On The P-Pump
  15. signs of starter going bad
  16. Seeking higher MPG
  17. Fuel Pressure Question?
  18. Iam lost
  19. Preheater
  20. Doing Killer Dowel Pin and Injector timing together?
  21. Sport Headlamps?
  22. TC coming apart?
  23. drop visor
  24. ball joints?
  25. overdrive solenoid
  26. Low Fuel Pressure Warning Light Needed?
  27. need some dodge help
  28. Fuel pump timing?
  29. how much my truck worth
  30. redneck way to set timeing?
  31. 94 missing
  32. 47re ?
  33. Timing Your P-Pump
  34. stacks
  35. Drag strip
  36. oil leak
  37. light switch
  38. turbo boost
  39. banjo bolt
  40. Boost gauge problems
  41. Auto trans shifting problem
  42. fan
  43. oil leak
  44. valvebody and torque converter install
  45. Dash Pod
  46. grid heater gasket
  47. fuel plate and exhaust temp
  48. Valve cover gaskets
  49. TPS
  50. what kind of injectors?
  51. delivery valve holder
  52. fuel filter right?
  53. Compression Test on 95 Dodge
  54. truck wont idle!!
  55. EGT'S
  56. 1996 ram diesel fuel lines
  57. ht3b exhaust housing
  58. nv4500 swap!
  59. still no start,I WILL PAY for your time!
  60. Automatic Transmission Manual
  61. help
  62. Oil Covered Injectors
  63. lift pump ,question
  64. nv5600
  65. how bad
  66. oil pressure
  67. fusable link
  68. injection pump gone....
  69. nv4500
  70. I need help!!!
  71. lock problems stilllll!
  72. egt issue
  73. 4x4 acuator
  74. how much is my 96 cummins worth
  75. starter problems
  76. truck died
  77. Towing mirror
  78. swaping injectors and fuel plate hp diff?
  79. breakaway screw
  80. Injectors and tranny?
  81. Fleabay Timing Tools?
  82. Brake line
  83. another afc ?
  84. aftermarket fuel filter help
  85. injector and fuel plate questions
  86. fuel plate
  87. Front Driveshaft Question
  88. 370 hp marine injectors
  89. Truck starts..almost stalls..then runs ok
  90. tranny pressure
  91. injection pump problem help me
  92. valve body problems i need help!!!!
  93. turbo help
  94. Block Heater
  95. oil under truck
  96. what year the 215 injectors start?
  97. Tuning!
  98. axle joints
  99. CCV Into The Exhaust?
  100. tranny fluid
  101. Squeal
  102. climate control...comes out defrost when set to cab
  103. timing 911 need help asap
  104. Transfer case busted
  105. turbo = junk
  106. 12v Stalled and won't start
  107. tc qestions
  108. Engine Pulsing & Breaks Up When Its Cold.
  109. replaced fuel line...still starts, runs, dies
  110. idle adjustment on a 12 valver
  111. Thermostat
  112. squattin hard
  113. 2wd to 4wd
  114. GEN light on
  115. pump timing
  116. Changing diff oil - torque spec?
  117. What size turbo?
  118. HOLE in return line in TANK
  119. Fuel Lift Pump Troubleshooting
  120. Black diesel?
  121. Trans Temp Gauge Help
  122. intake heater working or not?
  123. speed sensor wires testing? also alt pulley size?
  124. Initial 1 – 2 shift delay with 47RE
  125. Home Made Twins
  126. Plugging Waste Gate Pros and Cons
  127. afc screw?
  128. who has done it? 47re to nv4500 swap
  129. tow power
  130. new starter for 1996 cummins- $120 free shipping
  131. 12V Head Gasket Blown?
  132. TOURQUE CONVERTER HELP--96 12V AUTO
  133. Lag
  134. cruise control
  135. Vacuum pump gasket
  136. Update on starter
  137. biggest tires with 2" level kit?
  138. Dissapearing Oil
  139. Billet input shaft
  140. new to here and to diesels for the most part
  141. AFC
  142. oops!
  143. whats the be atf?
  144. Input Shaft
  145. harmonic balancer
  146. whats the differnce in the trannys?
  147. timing cover bolts
  148. Starter not engaging
  149. Is This A Factory Recall??
  150. help
  151. How to bleed at injectors
  152. KDP
  153. Making a 47RE work in a Swap Situation
  154. 4x4 disengages.
  155. changed overflow valve,lines,STILL HARDSTARTING!!
  156. comp button
  157. Intake Horn
  158. tranny codes i need help ASAP!!!
  159. ** POSTING THREADS - READ THIS BEFORE POSTING ! **
  160. Heater grid issues?
  161. Steering issues
  162. water in my dash?
  163. Just killed the KDP - Problem with speed sensor
  164. 4wd noise
  165. nv4500 swap?
  166. purchasing a 4x4 12 v,WHAT to look for?
  167. hx35/40 hybrid exhaust housing.
  168. 4X4
  169. mpg average
  170. new truck
  171. bump timing or wait?
  172. wierd code???
  173. timing?
  174. modifying my 12 valve
  175. what you think of this
  176. Truck porn
  177. sun cracked dash cover
  178. P Pumping a 92
  179. emissions
  180. Crankshaft help
  181. heres a thought
  182. ? of the day
  183. KDP
  184. hp
  185. 12v gauge readings, power for towing etc...
  186. turbo question???
  187. diff between 8 and 5 plate?
  188. Wheel Bearings
  189. boost line T
  190. fuel heater
  191. blower motor and wheel
  192. plungers and barrels
  193. valve adjustment
  194. wat to grind fuel plate with?
  195. after market head studs?
  196. Crankshaft Position Sensor Round 2
  197. Grinding Fuel Plate
  198. all the crap in front of the intercooler
  199. NOOB question i know
  200. 2 Piece Fuel Plate
  201. recall question
  202. Transmission Swap
  203. How To Set Your Truck Back To Stock Timing?
  204. fog light wiring
  205. Silencer Ring
  206. KDP
  207. home built head studs
  208. is this possible?
  209. 3k gsk
  210. would this work on my truck?
  211. breakdown
  212. 215 INJECTORS
  213. Cummins power pricings...
  214. Hard starting ,already changed fuel filter....crack line?
  215. fog lights
  216. where to get a boost elbow adjust screw?
  217. what is the best Valve Body
  218. slower after gsk
  219. heater grid delete
  220. steering & a/c clutch
  221. Torque converter?
  222. cruise control
  223. Steering Issues
  224. A/C pulley
  225. low speed jump.
  226. lag
  227. exhaust
  228. painting the bumper and the grill?
  229. Starting Problems
  230. New tranny or buildup?
  231. no overdrive?
  232. #0 plate vs grindin vs guttin
  233. stack makin a mess
  234. clutch slipping
  235. High idle?
  236. glad it happened on the farm
  237. somethins wrong
  238. Whats the difference?
  239. what is my hp
  240. Low Boost High EGTS
  241. 7-inch stack
  242. Brake Light!
  243. Electrical Problems
  244. billet parts
  245. torque specs
  246. infamous death wobble
  247. gauges not quite right
  248. mirror help?
  249. Need rocker arm pedistals
  250. 3k gsk
