- Advice Needed
- need help bad please
- difficult to drive
- More problems with my Truck
- Voltmeter fluctuating
- Front Axle and 4X4 light Problem
- NV241 HD transfer case question
- Smoking too much?
- turbo was sqwuelling
- Need to know about VP44's
- Quick module question, DiabloSport vs. Quadzilla
- turbo?s
- Can I Stack Chips on my 01 24v
- 1999 auto tran
- Bit the Bullet
- Might have to sell
- power ?
- ecm location
- factory chevy 8 luggers
- questions about fuel filter canister?
- apps symptoms
- cabin filter
- manual trans swap
- New VP vs. Old VP
- Truck has been surging any solutions.
- Turbo shaft play help!!!
- Cummins won't start when hot
- Engine Trouble (fuel issue?)
- Need help from the VP guys
- whats thediff. and how can you tell
- question about idle?
- IAT and MAP cleaning
- Speakers size?
- So Who Can Solve This Mystery
- Who's E-Brake actually works with bigger tires?
- question about quadzilla xzt
- Ext oil coolers?
- a couple of questions
- hx40 turbo
- Injector Lines
- What do ABS+Brake+Speedometer+Parking break....,
- quadzilla stop the defuel?
- 1999 Dodge Fault code
- attintion all ladies and gents
- LP questions
- chip
- what do i do or use to fix this
- Headache Rack?
- batteries
- 53 block Crack repair
- Reman Kits
- Death Wobble?
- need help guys big problem
- Banjo bolt thread size
- Problems with Gates Rad hose
- 99 3500 auto trans trouble
- Honestly?
- Front driveline anybody...?
- Truck gettin a little hot while in traffic and around town.
- Intercooler
- push rods bent
- quadzilla addr. fuel press questions
- Taking a part the front axle
- Truck Popin On Acceleration with Edge in 5,4,3
- Had temp fluctuations... checked and noticed coolant is brown and muddy
- Need help with my trans
- to sack or not to stack
- Break in period for rebuild
- K & N Air Filter Cleaner
- Fuel Systems
- Quadzilla Adrenaline
- who makes it?
- FP questions
- Alarm Troubles
- which is safer?quadzilla adrenaline or Edge juice
- tow mirrors
- Trade your 3:73 dual rear for my 4:10 dual Rear? Or should I just Get Huge Tires?
- Rear Main Seal leak
- Pressure testing intake system.
- Cruse Control Quits.
- 2002 Cummins 24V Valve Adjustment Video
- kickdown cable adjustment
- Quadzilla tunes and limits
- 300000 km service
- I think I need to replace the lift pump
- quad adr w/pulse
- wheels
- P codes
- A Documented Rebuild?
- Single Disk or Triple
- next best mod??
- 24 valve rebuid
- Cooling system
- "Damaged" VP44
- How hot is too hot?
- Headlights Flicker at Idle
- Know of any preferred diesel mechanics around N Alabama
- Cleaning Sensors
- fueled for power
- turbo
- Specs for 01 and 02 engine and turbo
- fuel pump
- valve body or torque converter???
- Edge EZ adapter question???
- Vp44
- injection noise
- Time to winterize
- The raptor LP
- DOES ANY ONE
- Fitting size on 01 Fuel Filter assembly?
- need help
- Rear Drum/Disc Conversion 2001 Dodge
- what does fuel pressure need to be on vp44?
- 2002 ram idling problem
- exhaust brake
- head studs needed for quadzilla adrenaline w/ pulse? if not, than what?
- more questions
- head studs and waste gate tubo fooler needed with quadzilla adrenaline?
- dead miss and deal pedal... ive tried everything
- cracked manifold
- Bd or suncoast??
- Clicking in front end in 4X4...
- Any easy engine upgrades, tweaks, or swaps for a 98.5 24v?
- boost leak???
- quadzilla help
- Need stock control arms specs
- Just lookin for ideas
- valves
- What aftermarket radio head unit will fit?
- vp44 bracket
- 47re valve body ?????s'
- what mods needed for 4k?
- I NEED HELP PLEASE About this TURBO
- gear puller?
- Injectors
- need some info
- Airsep Kit for crank case breather spray worth it? any home made alternatives?
- monster VP lope
- New 99 ram owner needs some 911oil leak need help!
- fuel injector removal
- Doors keep unlocking!
- Transmission Ideas
- I cant figure it out
- help please
- new guy with a major problem
- 01 Dodge 3500 Auto Tranny Problems
- need an opinion
- How to find rearend ratio?
- steering stabilizer
- FASS fuel help
- death wobble
- 01 ram 3500 heated seat
- fueling
- heater is not so hot
- LP Pressure
- Time to spend some money
- Problem with my over drive
- PPE Lift pump same as Edelbrock?
- got an airdog 150 had nothing but problems
- G56 in a 2nd. Gen.
- NV Manual Transmission Swap question
- Turbo Problems???
- New to the Diesel World
- 2001 with trans controller out
- Jet A/JP8 fuel use
- bleeding injectors
- broke something
- Changing gears Ratio.
- Stock valve springs
- 5 speed
- exhaust questions
- she runs a little funny, I think....
- Airdog 150 ?
- Shift kit
- I'm back! With a 24v question now...
- pop test injectors
- stuck in OD
- Dipricol Gauge
- funny feeling tranny
- injector line leak
- TQ Converter
- My first upgrade to my cummins
- trans question
- cab light leaks
- Lopping
- Been let down
- crank shaft position sensor
- lookin at an 01 2500 QC
- MPG question
- Need some help....Omaha, NE
- Wastegate Adjusting
- HOW MUCH HP A STOCK AUTO TRANY WILL HOLD
- Silencer Ring
- inctor conner tube ???
- Auto Transmission problem
- curious questions
- BEST PRICE ON VP44
- Three codes come up
- not shifting right....
- BHAF
- no brake lghts need help
- whats the best
- need to know info
- which way to hook gauges up?
- 2001 2500 Woes
- muffler vs straight
- 47re stuck in limp mode
- Hesitation problems got me puzzled
- Surges on highway, runs great under load
- 2001 Cummins Turbo Prob
- Surging Truck
- Exhaust manifold!
- stacking power
- h.o cummins
- Electronic High Idle Kit
- trans not shifting out of 1st
- If you had the opportunity... Would you sell?
- wiring problem
- whats wrong???
- Transfer case pops out of gear
- P0216...But...
- Threads on Gear Shifter
- Quad cab door not opening!!
- apps troubles or something else?
- trans funny
- frozen hubs
- Whats it worth(i know another one of these threads)
- silencer ring
- What is wrong with my truck?
- Come and Gone Trouble Code... P0121 Ideas? Suggestions?
- power steering fluid all foamy
- hesitation @ 40mph
- Shuttering
- Broken NV4500 5th gear
- Intermittent Starting
- Dodge 3500 brakes shutter rear wheel hop
- 53 series block
- something wrong with my ac
- more power
- 2001 wont start
- advice on getting 02' diesel
- not running right
- transmission fluid etc
- Wiring Problem
- Long Cranking Before Starts
- How many quarts of tranny fluid
- Before I turn it on
- my friends fuel problem
- My Favorite !@#!&*! Yellow Lght
- Check engine light!!!!!!!!!!!!!!
