- Potential 95-97 K2500 6.5l Suburban purchase??
- Best way to remove 6.2L pre chamber
- power steering squeal
- Manual transmission versus automatic?
- 6.5 need help asap
- Getting 33, 34, and 78 codes
- new diesel owner needs help
- HELP please
- HELP please
- What are the best "in the driveway tests" you can do to a 6.5 U R thinking of buying?
- temp rising
- Bleeding fuel lines after Lift pump replacement
- 95 6.5 k2500 HELP PLEASE?
- 2001 GMC Savanna 3500 6.5L Non-Turbo is not starting!!!
- What year did the 6.5 get the cooling improvements? Please help...
- 6.5 fuel filter relocate
- what tranny do i have ?
- Can't find my fuel filter on 98 6.5 Sierra
- exhaust
- What else should I do if I take the intake manifold off
- How cold is to cold?
- 6.2L secondary fuel filter?
- Fuel filter replace
- new to the diesel game
- What the heck??!! Bad valve?
- 6.5 TD Problem Child
- OPS mod
- yet another question
- injection pump
- pmd question
- 94 engine temp fluctuates a lot after OPS mod
- post pics of Detroits!
- please, very cold morning, started,died,now no power
- Cluster problems 94 chev
- 6.5L TD stalls
- Shifting issue
- 6.5 td small fuel leak
- Diesel ??
- Need a little help/advice with my 6.2 power project
- 6.2/6.5 hybrid motor
- Headlights and Radio Flickering
- Tailgate Conversation (98 Tahoe)
- silencer ring
- turbo issue?
- Please help no start
- 99 k2500 chevy suburban galup
- Replaced Batteries Wont turn Over
- Intake Heat Shield
- 1995 2500 HD
- 6.2 and 6.5's near you
- Diesel dump
- possible issue
- catalytic converter
- inj pump rebuild
- my 93 6.5 td needs help me help it
- Fuel pressure observation
- Plz help me
- Turbo whistle?
- Third row seat
- 6.5 turbo cold air intake
- HELP please!!
- 95 chevy 6.5 no start
- Pre heater for 96?
- 94 Burb 6.5 turbo project/driver
- 1991 6.2l coolant leak
- So I am considering a barter of my 97 Burb - what you think?
- Help with RV - Chevy 6.2L engine
- what's the advantage of a larger fuel lift pump and feed the beast mod?
- 6.5 surging?
- Exhaust Questions
- noisey lifter
- 1994 C3500 dually 6.5 TD
- Hit ditch, Vacum pump making noise & 4X4 not engaging...
- 98 6.5 fuel starvation/ops question
- 1993 Chevy 6.2l, white smoke, shaking, missing.
- 1993 chevy 6.5 td wont run
- Please help! Chevy M1010 from WI stuck in Indiana!
- 6.5l fuel problem
- 97 6.5 shut off at idle after warm ?
- 4t60e on a 6.5?
- 95 6.5
- Trouble keeping 98 chevy 6.5 running
- 94 Chevy 3/4Ton 4x4 6.5 Turbo
- How do I make it blow more smoke?
- 95 6:5 antifreeze leak at startet
- 1996 6.5L turbo: fuel injection pump
- 6.2 compression in cooling system
- swapping 94 6.5TD in 98 K1500
- 6.5 or Cummins turbo on 6.2
- Another 6.5 hesitating thread.
- 96 2500 Build
- stalling at idle
- CDR canister "tuna can" removal how to???
- 6.5 gmc will not start!!! help
- AC delete pulley
- Air Compressor
- 1996 6.5l rebuild
- 95 6.5td good aftermarket lift pump
- 6.5 TD Turbo and Electrical Problem?
- fix one problem to have another
- Considering adding dual CAT 3 micron filters just after tank.
- Need tranny help ASAP
- 6.5 diesel questions from a diesel newbie
- 6.5 problem
- 1996 chevy silverado 2500
- My new 6.5
- 2000 chevy 6.5 not starting
- Manual Turbo Control
- How to completely flush the coolant system
- 93 6.5 turbo starting problems
- 6.5 turbo 12mpg help
- 6.5 turbo going crazy!
- Will mechanical 6.2 pump work on 6.5?
- Thoughts on Biodiesel
- Fixed check engine light! (2 cycle oil)
- upgrade parts
- 95 6.5
- 6.5 issues
- 93 6.5 turbo exhaust
- First Diesel, Should I buy this 1995 GMC 6.5
- help with air in fuel lines
- Help me trace, lots of smoke, no power
- My kid tried turning up my 6.2.....
- missing at start
- 93 6.5 turbo ip MORE POWER!!!
- IP replaced, now leaking oil
- new 94 Burb 6.5l turbo
- opinions on the 6.5 Detroit
- stalling and stuttering only after starting
- 6.5 td starting problems
- Winter is almost gone here..
- 1991 6.2l OPS
- CODE 78
- 4l80e to nv4500 conversion
- What are your thoughts regarding oil at CDR/PCV discharge line????
- Stalling problems
- 98 6.5l sputtering problems and stalling
- 6.5 turbo injector rebuild
- 6.2l wont start when warm (old issue i know but please help)
- headlight issues
- 6.2 turbo oil supply
- Tow Mirrors
- 1999 6.5L Surging under acceleration
- 1996 6.5 hard starting and in limp mode
- grounding pmd
- 1999 Suburban 6.5l won't start
- 94 Chevy 6.5l problem start and running
- Cruise control dead
- diesel computers for 6.5
- ssdiesel Fuel Miser Injectors
- what are these check engine codes??
- 6.5 Diesel Blow Starters Solenoids
- 94 6.5L No Start - ECM reading ECT incorrectly
- upper radiator hose
- 98 6.5 gmc starting issues
- will a 1993 fuel pump fit in a 1999?
- 1986 6.2L K5 Blazer - won’t start
- 93 6.5 turbo batteries
- 95 chevy 6.5 keeps shutting off!
- coolant loss
- 93 6.5 turbo funny start up
- Oil pan
- Glow plug issues
- How to swap a DB2 Injectin pump
- 93 6.5l Turbo Diesel Idles but dies at 50MPH
- Help needed please - What is best place to relocate a new PMD?
- Fan clutch
- 6.5 im trans questions
- 6.5 on then off
- Need buying help!
- 94 NV 4500
- White smoke
- 6.5L no boost
- 96 6.5 Vacuum system?
- 84 blazer 6.2 diesel
- Oddest thing I have ever seen...HELP
- HELP 2000 6.5 CHEVY COOLANT ISSUE'S
- 6.5 Glasspack
- eastsideglass
- no start ? simple fix?
- Electric fan versis mechanical
- issues with a 4x4 actuator....help!
- FIXED MY STALLING 95 !!!
- 4x4 dually tranny
- 94 6.5 turbo diesel not running
- help!! 95 2500 6.5
- 91 6.2l head gaskets
- 6.5 turbo diesel stalling
- 6.5 idles ruff but not in gear
- 4l80e swap
- Low Gear or No overdrive
- crank sensor
- 1995 3500 6.5 Diesel Started Yesterday, Dead Today
- lift pump not powering on
- 6.5l TD will not start.
- alot of air in bleed off valve on fuel filter
- water/methonal injection
- 6.5 won't start after sitting about an hour, til it cools off.
- 98 chevy 6.5 TD won't start now
- dose the lift pump run all the time on a 95 6.5 td
- green antifreeze to pink
- Surging at speed
- 1982 Chevey C-10 6.2L
- 93 vacuum lines
- 1995 shortbead extend cab 6.5L turbo
- Vegie oil conversion kit
- 95 k2500 6.5 turbo Auto trans
- 96 gmc 6.5 problems starting
- 6.5 popping back in intake
- blow by
- 6.5 turbo diesel shutting off
- Miss/sputter at high RPM
- 6.5l 95 chevy 2500 no glow plug or wipers
- Where do you get Performance parts
- 6.5L check engine light
- 6.2 swapped to a 6.5 non turbo I WANT A TURBO
- 4l80
- 6.5 Thermostat location?
- Tire size
- coolant pressure
- A Sick 1995 6.5 question
- any fix to a injection pump on a 95 6.5
- 2WD to 4WD conversoin??
- 6.5 backfireing
- 6.5 long block?
- 6.5 help
- detroit diesel decal
- All you 6.5 gurus
- New to 6.5 No Start
- 1995 chevy vin p 6.5l no dash lights or glow plug light
- Combustion in coolant
- 95 gmc starting issues & more
- 95 chevy 6.5td cummins swap
- 6.5 blazer power problems
- 6.5l keeps dieing help
- Confusing running issues
- 96 6.5 wont start NEED HELP BAD
- glow plugs 6.5 td
- 1995 Gmc 2500 pops and sputters, AND TAKES OFF?!
- used engine oil for fuel
- 6.5 turbo intercooled HZJ105 R Toyota
- 1998 Chevy 6.5, revs to 1000rpm but thenld its self there
- 250k + miles on my 6.5
- 6.2L rebuild???
- KING PINS?????
- 6500 and penn 400 redisgned block
- 6.5 with 193k miles
- 6.2 diesel glow plug relay LOUD
- Oil Cooler line removal
