- Blade count
- Anyone know the specs for a Cummins/Holset turbo HE07VGMR?
- welding
- can anyone give me an estimate of hp I should be running on my Cummins
- welding
- what is wrong with the alarm on my truck?!
- ext or crew cab??
- machined or polished
- Safe to Run Smarty w/ These Transmission Mods???
- ugh bummer
- limp mode/map sensor
- 3rd gen wheel price
- rebuilding top end
- Anyone Using Smarty POD???
- edge additude giving false psi
- fuel pressure
- DIGITAL OR ANALOG GAUGES?
- Small thumping
- Who is the guy in this video?
- Best Aftermarket HD Bumpers
- Tuners Outlawed?
- Truck names
- Is painting rims worth it?
- Swaping 47rh into 99 cummins HELP PLZ
- 24v P7100 conversion
- *HELP/ Please answer this question*
- ECM Reflash? how do i know?
- Are Discoverer m+s winter tires good?
- Looking into buying 03 cummins
- Whats the biggest size of tire I can put on my Cummins 3500?
- dana 80?'s
- question on interiors
- Cummins swap
- pros/cons
- What to paint my my underside with? por15 or rustoleum undercoating
- Powertrain Control Module question
- hot EGTs for short times??
- help! ECM question
- Dodge Rims, will they fit on ford?
- early powerstroke vs early cummins??
- cummins 1st to sec gen moter swop
- 5in straight pipe for stock truck?
- here she is
- new to me 06 cummins, need some input
- want dodge to run on home brew
- 5.9 or 6.7?
- Cummins Owners Unite Help a Cummins Win Truck of the Month
- Name That Turbo!
- Exhaust NEWbie
- Meet the new 2013 RAM HD Trucks...
- Should I cut off my catalytic converter when installing stacks?
- 2005 ram 2500 cummins weird problems
- Thinking of purchasing a Spool-Aid Boost tube
- 1979 Power Wagon and a cummins engine?
- Need Help!! Loud knock
- 1st Gen Gauge Cluster
- Blacked out Tail Lights - the right way with pics!
- 6.7 belt and pulled noise
- Got gifted with a Cummins N14...
- cummins expert mechanic advice needed.
- Miami Dodge Dealer
- 88 dodge won't stay running
- 96 factory evs alarm problems
- Turbo clamp help
- Which year and config for towing
- amber lights under doors..
- HELP!!!!! spyder projectors
- BRAND NEW H&S MINI MAX....FOR SALE OR TRADE.
- JEGS huge Sale on Turbos
- Cummins seat swaps?
- painted headlights
- Reputable shop in Mt Pleasant Tx area?
- 6.7 straight pipe help
- how is this possible ??
- why do dodges trannys go bad so soon?
- fass vs airdog
- What tire?!?
- 94 6 speed cummins with 3.07 gearing?
- BUYING A 93 CUMMINS POSSIBLY. HELP!!!
- Reverse Lights/ new setup
- Baby stuff
- Making power, will it hold?
- Dodge outsourcing ??????????
- need a BARK!
- 5.9 or 4th gen 6.7
- tranny
- Are the 1st gens any good?
- need help
- COMPANY NEWS; CUMMINS AND BRUNSWICK FORM VENTURE IN BOAT INDUSTRY
- Tow Mirror Problem
- Fuel tank setup
- newer 6.7 reviews ?
- After market headlights.
- Spider gear Shims on Chry 9.25 axel
- New around here yes I have a cummins
- If this was your truck.....
- need help? do i buy a 2012 or order a 2013
- little help
- how many miles is too many
- Altered Ego wins Super Stock Diesel Trucks at Bowling Green
- Looking to buy 7.3L Powerstroke or a 12v Cummins First Truck
- engine noise
- For Sale
- Need help new and looking to buy a Cummins
- Anybody
- Would like your thoughts
- help,my 6.7 clutch won't work!
- turbo upgrade??????
- how much.....
- What's the best year for 3/4????
- How do I tell if my 98' cummins is a D or a 6?
- 2005 3500 auto into 98 3500 auto trans swap
- 2nd gen reg cab room
- semi tire and wheel change over
- Explanation Please
- Sony Xplodes
- 2500 vs. DRW 3500
- 99 Dodge Ram 47RE Troubles
- PASSWORD TO THE BADLANDS
- 53 block
- Info on Dodge four door Trucks Plz
- Treadwright TIRE UPDATE
- Help! Newbie! Should I buy???
- 2ND GEN DUALLYS
- Upgrading Injectors
- Stacks Question
- TRANS FLUID help ?
- 98 Dodge ram diesel with no tach, speed or oil
- Build or buy?
- Cummins in a 71 chevy 2500?
- ceramic clutch
- Stacks
- Question for the Cummins folks..
- 2nd gen dodge frames
- Tranny!!
- clankin sound
- Worlds First!
- Hello
- Cummins swap
- dont know what to get..
- bed swap
- egr delete
- OEM Grill Emblem?
- Front Ends: How Long Before You Replaced Parts?
- fuel pressure & rail pressure
- My first Questions about my Cummins
- You have got to be kidding me
- Dual Liner Bed Liner For The Dodge Mega Cab SB 5'7"
- Differential Additive / chatters when making tight turns
- Ask a Cummins Tech
- Need some help
- what should i pay
- Brake question
- 02 dually tire help
- Cumming Grille Emblem
- Free Chiltons Online
- Tryin to put new dolor speakers in
- What do you think?
- What's it worth?
- Very stiff rear springs
- My new toy... 12 Laramie Longhorn Crewcab dually
- 06 5.9 tranny issues
- Need idea's (gonna sale the 96')
- New 2012 3500 Ordered!
- What's it worth
- 5 or 9
- Thanks To Your Help I Found My Truck!!
- needing i new truck wich is beter 12 or 24
- Do You Know Cummins?
- Opinions needed, should I or shouldn't?
- Found this and thought id share(Online Repair Manual)
- Cummins Crank Scraper?
- mudFlaps?
- What truck to buy? high mile 12 v or low mile 24v?
- Sunroof or no sunroof?
- Powerstroke guys always bashing on the Cummins 5.9
- The Other Guys... Dahl and Fleetguard Fuel Filtration and Processing
- nv3500 oil
- audio
- Rounded tip Stacks
- please help, dana 60 axle problem
- 6 speed conversion help
- 5.9 vs. 6.7 question
- Bombers t shirts
- Exhaust
- Rear wheel bearing adjustment 93 D350?
- To trade or not to trade?
- Common Rail Injectors
- 1990 international with cummins
- So Long Steering Wander!!!
- Crankcase tube smoking. Normal?
- RUST!
- RUST!
- Info needed to help my NV5600
- DRW vs. 4x4
- Please help!!
- Tbone 95
- will this tranny work
- What to be aware of on dodges
- Newbie
- How many RPMS?
- IDEAS NEEDED!!!!!!
- 4th gen wheels on a 3rd gen?
- Truck Goes Up in Flames
- Hood Sensor
- hydro-boost problems
- Spool Flange
- How bad was your day?
- downpipe problems
- 6.7 deletes New to the diesel world
- tow mirrors
- Found these parts in my oilpan????
- Fuel rail pressure
- Repair Manuals on CD??
- Steering/gear selector lock
- motor swap
- cummins diesel tech.
- Installing Cab Lights
- pillar gauges with edge???
- edge fuel press. help
- My plate Bumper I built
- Attn Snow Plowers:
- Off road light Idea's??
- In the market for 8 lug axles...
- Charging System Issue
- anybody near ks?
- new truck
- Cummins Swap
- Locations of totaled dodges
- $160 Screw Up!!!
- DPF qquestion
- Need HELP with with CRAZY LARRY ON PMT
- Cam
- Black or smoke lights
- Found the Reason (Front End Shaking)
- Diesel Treatment for winter!
- twins
- tired of epa
- Ideas Please
- truck ideas
- witch is better turbo for a set of twins.
- lookin for a new truck
- anti rust help!
- Marker Lights Help
- Finally Got THAT Out Of the Way!!!
- Anybody in Rowlett,TX
- Some schematics for troubleshooting fuel gauge issues
