PDA
View Full Version : Dodge Truck and Cummins Turbo Diesel Forum
Pages : 1 2 3 4 [5] 6 7 8 9
  1. 2006 ram 3500 non dually
  2. 88 chevy dually 12v swapped
  3. towing mirror repairs
  4. 12 valve straight pipe vs 24 valve straight pipe
  5. Tail Light issues
  6. DMV fees California??
  7. 2010 VS 2011
  8. Down pipe for HX35
  9. manual valvebody
  10. keep or sell???
  11. side rails, what do you think?
  12. cummins in a 1993 F150
  13. 10.9 vs 12.9 flywheel bolts
  14. upgrades
  15. headlight restore- WOW
  16. Pic request! Can you help?
  17. My 8.3 is having troubles starting in the morning
  18. i need to see pics!!!! thanks!!
  19. smog test
  20. hit and run
  21. TRUCK NAMES
  22. Front Driveshaft Help
  23. PYRO help
  24. turbo questions please help
  25. setting up alternator sensored tachometer
  26. odd truck with cummins needs more power
  27. 48RE
  28. Hid headlights
  29. reman tcases
  30. sharing information
  31. help quick need to know today
  32. Got my first cummins!!!
  33. AC issues
  34. Gauges
  35. transmission kicking out of overdrive
  36. 2003 wheels on a 1996
  37. Guess I'm doing ok
  38. Fuel Filter
  39. The names of the Cummins
  40. gasket set
  41. whats up with this?
  42. Color Confusion
  43. blocking return line
  44. rig of the month on cf
  45. In the market for a new truck
  46. p-pump or common rail
  47. 1st gen beds
  48. lifted 2wd?
  49. 10 Mega Switch Question
  50. finally!
  51. Will They Fit?
  52. 4BT with 5-speed 2k
  53. Dodge Cummins FLTT
  54. alcohol injection
  55. 99 Dodge V-10 not shifting out of 1st???
  56. trailer brakes
  57. 8lug in Afghanstan
  58. What Engine?
  59. My Buddy Got A Feature in Diesel Power
  60. Front brake help
  61. Cummins Lift Pump Upgrade
  62. New 6 speed
  63. 9 or 10 speed behind a 6bt
  64. cummins visor, not for your truck but for your head??
  65. Need Help with 01 Cummins
  66. weight bracket mounted. what yall think?
  67. Good deal on the SUPER B SPECIAL turbo
  68. black stacks.
  69. Extended Warranty
  70. Radiator Questions
  71. '01 wheels for an '89?
  72. stacks
  73. Inner shaft seal
  74. Anyone got pics before and after leveling kit on 2wd?
  75. Safety Recall Notice 03-09 dodge
  76. wheels?
  77. No/Very Low boost problem
  78. 12v in a 05
  79. 12 V $1900????
  80. killer dowel pin years?
  81. locker
  82. Best MPG additions!
  83. vacuum pump is leaking
  84. New guy needs a long bed!
  85. bumper gap
  86. steering box
  87. Cummins Turbo Diesel High Mileage Club
  88. Steering
  89. ball joint replacement
  90. Front and Rear Brake Job
  91. Tailgate rever light upgrades
  92. exhaust tips
  93. ask the pros
  94. Gigantic Detriot Diesel Dodge Power Wagon
  95. what year NV5600 6spd
  96. Headliner Removal
  97. quadcab rear door latch not working
  98. BD short shifter for cummins?
  99. Wheel Studs
  100. Highest rpm ever recorded on a cummins!
  101. Rims & Tires
  102. NAPA Brake Pads
  103. Question about my exausht
  104. What Part Of.....
  105. question
  106. what is a good shock for towing and big slid in camper??
  107. The History Of Dodge and Cummins
  108. Looking for link to the service manuals.
  109. customized license plate
  110. just another compound question
  111. 2nd gen 2wd UBJs
  112. word of thanks
  113. NEW TRANS WHO MAKES THE BEST???
  114. Got it on the dyno
  115. Scotty Air II
  116. highest hp record on a hx35?
  117. Transmission finally went out..
  118. Wheres Your CB
  119. Got my new steering box brace!!
  120. Aftermarket Bumper Pic Request
  121. 2006 Front bumper on Craigslist
  122. 2nd gen cummins roof thickness?
  123. Torque convertor lock up switch
  124. Help! megacab longbed conversion
  125. shackle flip?
  126. KDP question
  127. still truck shoppin
  128. 47re differences?
  129. gear housing removal
  130. Where to buy turbo
  131. how to install H2 wheels
  132. Rock Slider Type Side Bars?
  133. Check this out if you are thinking of an intake system!!
  134. twin turbo question
  135. transfer case question
  136. 5.9L rattling parts
  137. air conditioning condensor
  138. 727 weight?
  139. 12 valve to 24 valve
  140. vacuum pump oil line
  141. Need input (Susp. upgrades)
  142. 5.9 or 6.7???
  143. Need a little insight here.
  144. General ?'s about CTD
  145. V10 to Cumminns conversion
  146. 99-02 cab lights vs 03-08 cab lights
  147. Mystery noise?
  148. best muffler for cummins motors
  149. Installation of a 13" ValAir Clutch Conversion
  150. Thinking of putting it up for trade...
  151. Upgrading to a Heavy Duty Clutch Hydraulic
  152. Fixing Your KDP On The Cheap
  153. Bosch Injector Tech Data
  154. How do Cummins compare to Duramax and Powerstroke ?
  155. Trans off a V10 96' fit on a Cummins 96' ?
  156. Chip levels?
  157. transmission works great, but as of tonight, not as powerful
  158. Donaldson M100465 muffler installed
  159. NEW TRUCK
  160. 2010 Mega Cab 2500 4WD Tires?
  161. Fender Flair ???
  162. Tranny Temp
  163. Cummins on 2 Guys Garage the 24 th
  164. Mirrors
  165. Time for a Muffler !!!
  166. 93 cummins turbo swap with a 96 cummins
  167. engine specs
  168. 93 tranny?
  169. heated seat
  170. aftermarket HX40 turbo question
  171. One Milestone Reached Yesterday
  172. Dodge 3500 front rotors junk in a box
  173. Rear seat cargo tray
  174. wats it worth
  175. edge question
  176. 2nd Gen trucker mirrors...
  177. who needs HID lights in their dodge 06+
  178. Cummins box truck
  179. Weird vibration-Check your front driveshafts!
  180. Heater Issue
  181. Cummins block dimensions
  182. HID lights
  183. turbo questions
  184. Crazy idea or not?
  185. DODGE WORK TRUCKS
  186. Dodge Ram and Cummins Tech Thread
  187. guages
  188. Rims for the non punk
  189. Ram name
  190. custom bumper
  191. My kind of street rod!
  192. If It Wasn't For Cummins
  193. UPGRADES
  194. valves
  195. Manual high idle switch
  196. Vibration when letting of pedal
  197. has anyone here use this company
  198. Looking to get a 03-06 Dodge cummins..couple of questions..
  199. Stereo for an 06 Ram?
  200. bully dog?
  201. 2nd Gen Sterring Column Pics
  202. Oil for my dodge
  203. cummins pump swap
  204. 95 2500
  205. manual transmissions
  206. PICS PLEASE
  207. Looking to buy a truck next year.
  208. Recon light question
  209. Desperately Need New Seats!!!
  210. Whats my truck worth???
  211. 285/70/17's or 315/70/17s
  212. Muti-Function Switch Recall
  213. Ordered 2010!
  214. 3rd Gen Tech: Isspro EV2 Gauge Install
  215. Dodge motorhome rearend
  216. pro parts dual overhead pod #72040
  217. no psc steering boxes till jan. 2010 for 2nd gens
  218. Does a Cummins come with a license to be an ass!
  219. Where Can I Get a PSC Steering Box
  220. pros and cons of getrags and nv4500s?
  221. gearvendor overdrive, is it worth the trouble?
  222. VP44- p-pump, who has actualy done it?
  223. SAFE RPM ON COMPRESSION?
  224. 07 3500 reliability help
  225. Diesel Smoke
  226. Cummins Tech Article: BD Intercooler Boots install
  227. Oil standards
  228. Duals or Stacks
  229. dodge lifts and stacks
  230. 5.9CR or 6.7 for fuel economy
  231. Taking door off - second gen
  232. P0243 Turbocharger Wastegate Solenoid A Malfunction
  233. Front Ends
  234. Manhattan ? anyone close ?
  235. 24v commin rail to 12v head and pump swap
  236. 6 or 7 inch stacks
  237. which one airdog 100 of airdog 150?
  238. Question about quadzilla xzt tuning files?
  239. Twin turbo question!
  240. transfer cases
  241. John Deer injectors in a second gen 24V?
  242. Wondering if I could fab up an injector puller.
  243. Interchangability of 1st gen and 2nd gen parts
  244. Mud Flaps
  245. At A Cross Roads
  246. Cores
  247. opinions...
  248. Introducing the 2010 Dodge Ram HD
  249. 2002 cummins question
  250. good deal?
