- tuners
- using a vgt turbo as bottom turbo?
- how to put a 351 turbo on a 5.9 cummins
- T-46 Turbo. !READTHIS!
- 3rd gen hot pipe for my twins
- fueling issue
- Goerand Transmission
- Edge comp on and now my truck stays at full throttle
- banks exhaust brake
- fuel psi drops at IP when LP stops
- Chips And Programmer Need Opinions.
- Sucking Air & A Hard Start
- transmission upgrade
- turbo help
- t/c lockup switch. bad or good?
- All hot and bothered for nothing...
- used edge attitude
- ATS stage II transmission
- $300 HX40!?
- Drive Pressure Port?
- 35 40 hybrid
- heat exchanger relocate for twins
- what power upgrades should i get?
- Tapping vp44
- Looking for opinions on built trans
- Quad adr 4k or blue chip redline unlimited
- edge jwa stacked with smarty
- 1999 Cummins, Bomb direction
- Pressure gauge.
- p-pump w/auto trans
- What turbo do i need?
- Edge Comp differences
- Things I like to do to my rig, suggestions Appreciated
- Edge EZ
- BD stealth cover question!
- When to add head studs
- pinned fuel pressure gauge
- module problems
- quadzilla xzt problems
- Smarty?
- Cold Air Intake
- twin turbo custom fab
- DDRP Install
- Problems!!!
- Twin turbo set up
- upgrades for nv4500
- Smarty or Edge Comp
- Alright gentlemen,need some help with tires and rims.
- BD exhaust manifold
- My trans
- Chip / programmer question for a 98 24V
- What size injector?
- cam question
- s300
- twin setups which one?
- DTT?
- lift pump gauge help!!!
- in line fuel gauge?
- Programmer Help?
- edge comp box
- Air dog 150 help
- 2001 dodge towing
- New Fuel Only VP44 record
- 47RE Decisions
- Drive pressure gauge
- pyrometer should or shouldnt i
- twin turbo time
- lookin for mods
- too loud
- 4k Quadzilla Custom Tunes
- Smarty or Quadzilla Adrenaline?
- dual intake
- Squeezing mileage out
- Have a chance to buy an Airdog 150
- what turbo for quadzilla and 100 hp injectors
- 98 Dodge Ram 3500 2WD, Leveling Kit
- Edge or quadzilla??
- INJECTOR HELP!!!!!
- best cold air intake
- 1998.5-2000 Dodge 5.9L 24V Comp
- Faulty fuel gauge???
- Alligator Performance Stage 3
- injectors
- HE351 Swap
- s360sx or s362sx
- South Bend clutches
- Fass install questions
- exhaust manifold bolts
- Newbies Fuel System
- Ranch Hand Rear Bumper or something like it
- edge
- ts performance
- turbonetics turbo?
- Need more Power... Injectors???
- OK GUYS! CHECK THIS OUT!!!!!!!!!!!!
- Edge Comp Box
- Turbocharger Suggestions?
- 3 piece manifold
- quadzilla 3000 tune?
- tire clearance
- Edge wont turn on
- Need Opinions on Custom Intake Manifold for P-Pumped 24v
- bhaf
- Aftermaket boost elbow??
- Edge Comp or Edge Comp with unlock??
- Stock VP44 vs. Hotrod VP44
- 2'' or 2.5'' leveling kit
- injectors
- Converter question
- Is this a good combo
- ppump conversion timing
- aftermarket cam
- Good Or Bad Upgrade
- propane injection water meth injection mix
- who want to sell there adrenaline
- Which chip do i run?
- valve Bodies, what the difference over stock.
- Touch Screen Sound System
- Getting a 24 Valve to 800 Horsepower Safely.
- injector % usage vs supporting bombs
- injectors
- 03 intercooler
- EJWA-CTS Install Questions
- Extra fuel pump?
- Shifting the nv5600
- coal train injectors
- AirDog FRRP fuel pump
- looking for info about downpipe
- Diesel Power Source Manifold, and Phatshaft?
- Cheap 5 minute interior mod!
- better lights
- BHAF Intakes !
- mpg's
- Remote Start
- VP 44 tap probs
- Tune levels
- edge comp installed and tapped
- Is my head gasket going to survive?
- Edge Products Question
- fass 95 platinum and edge comp
- cab lights
- turbo help
- surgin down the fwy
- Glowshift fuel gauge problem
- Programmer
- Tax Time Up Grades
- Drilling a silencer ring
- raptor 150 install (inside frame rail clearance issues)
- Comp box and smarty?
- boost elbow
- Silencer ring in the stock turbo?
- Questions about Smarty levels
- semi lights on a dodge
- Power loss under load
- airdog 150 install question
- tapping the pump wire
- FASS stock replacement pumps
- programmer ????
- skeeered of the programmers
- stacking my quadzilla adren, with a smarty questions!
- Edge JWA
- fuel sending unit opinions vulcan liberty fuel module or other?
- intercoolers
- best all around chip
- who runs a 62/65/12
- Hard Starting W/O Ether and Dead Pedal???
- BD Short Shift Kit - 6 spd - Who has one?!?!?
- O-Ring VS. Fire-Ring
- New and Confused
- Dick cepek long arm kit install.
- need some smoke
- edge CS mount
- boost hoses.
- 5in or 4in exhaust
- Borg Warner s246 turbo
- s366 yes or no?
- possible brake upgrade and looking for info on injector nozzels
- how much power can my stock turbo handle?
- edge drag compatibility?
- Explain injectors to me please
- what injectors for me?
- Chip worth it?
- Lukes Link Questions
- performance ecm
- what to do with tranny
- anyone do a diy big line kit and draw straw?
- does it matter if a chip out of a manual truck goes in an automatic truck
- Edge Drag Comp
- stacking chips
- Suggestions for next steps on my new truck...
- 24v glacier pump or airdog / fass pump?
- 2001 dodge cummins
- boost press. psi ang egts with comp box
- what can i stack with an edge comp
- Fuel gauge, and fass issues help!
- can u fool the ecu?
- TS performance chip
- comp or quadzilla
- HTS valve body
- 6.7 turbo
- Thinking about getting a turbo timer.
- Built transmission
- EFI Live
- 2001 and a smarty ?
- What if??
- want more boost?? What can be done?
- compounds question...
- low pressure fuel light
- wanna p-pump my 24 valve
- ad165 install
- What to add first?
- Fuel pressure question
- Glowshift gauges only stay red?
- running out of fuel
- Whose running an edge EZ?
- gauge, vp or something else
- Torque Converter Lockup
- tuff country traction bars
- BHAF
- built 47re
- Head studs
- edge chip
- From 8 laying down, to 6 standing up...
- Blue Chip FMS ?
- Transmission died AGAIN
- injector nozzle removal
- EdgeCS boost?
- H.I.D conversion kit
- crsrt
- Whats next?
- garett m24
- Power max?
- injectors?
- EJWA CS Load Screen Stuck
- Help with performance upgrades!
- boost line install 2002 cummins
- Allright SMARTY...
- Diesel Auto Power injectors, any feedback?
- Twin turbos or p pump conversion????
- twins turbo hot pipe
- i want to roll coal for cheap
- horsepower number?
- fuel guage quit working
- air filter directly on turbo?
- cheap chip or programmer
- Couple of issues
- Injector hp
- Airdog 100 + FP Gauge
- smoke switch
- 150hp injectors
