PDA
View Full Version : Ford 83-94 6.9 and 7.3L General
Pages : 1 [2] 3 4 5 6 7 8
  1. Ball joints
  2. Oil in the coolant
  3. zf5 swap
  4. 94 7.3 IDI SURGING
  5. Ram Air Ideas on a 91 7.3 IDI
  6. What's the best epoxy to use?
  7. 1993 F350 7.3 Turbo will not start
  8. 1994 7.3 turbo IDI - too much undercarriage rust to justify purchase
  9. 94 7.3 IDI TURBO REPLACED RETURN LINES AND O RINGS STILL LEAK?
  10. Crank, but no start!
  11. starting issue
  12. Upgrading from a C6 to a ZF-5-Speed w. 4x4 - Transfer case question
  13. Need to replace my clutch and injectors
  14. 1990 F350 stopped starting
  15. need help 1985 F250
  16. 93 F-350 7.3 running/starting issues
  17. 85 f250 6.9 what's it worth?
  18. 6.9 high rpms at 55
  19. transmission problems
  20. now it willnot start
  21. Transfer Case?
  22. Starting Problems
  23. First idi!
  24. 91 f-250 7.3 IDI fast crank with new starter and batteries to extremely slow
  25. problems with the tranny
  26. Passenger day time light does not work
  27. Sites like JEGS or SUMMIT?
  28. New Buyer - ABS light ON, Can't get EEC Trouble Codes
  29. Saying hello
  30. she runs!...then dies
  31. Fummins Swap
  32. 1986 6.9 problems
  33. Anyone know of a good vacuum canister replacement?
  34. h1c turbo.. and lowering compression
  35. 1986 ford f250 diesel wandering at highway speeds
  36. Help 7.3 idi
  37. OFFTOPIC HELP!!!! 1968 internatinal harvester cub cadet 105 wont start
  38. 87 F250 5-Speed Swap
  39. Bleeding A Slave Cylinder...
  40. glow plug controller
  41. 88 7.3 wont start after intallation of manual glow plug relay.
  42. wipers
  43. tuning up my idi
  44. Where Can I find a Hydraulic Clutch Line?
  45. Block Heater Question
  46. Add a leaf question
  47. IDI IP pump tuning help
  48. Flashing overdrive..
  49. E4OD to t19??
  50. OFFTOPIC kawaski mule 1000 how turn engine by hand
  51. Good Buy? - 1987 F250 6.9 IDI
  52. Starter Won't Work When Cold
  53. Bigger injectors
  54. Glow Plug wiring
  55. Bad Injectors?
  56. 91 IDI injectors to 94 Turbo idi injectors
  57. '94 7.3 IDI TURBO GLOWPLUGS
  58. OFFTOPIC 1989 pace arrow motor home rear axle for trailer?
  59. New truck need help taking the gremlins out
  60. Wrong on the antifreeze additive
  61. HID lights?
  62. Can I put a 2000 7.3L powerstroke turbo on my 1993 7.3L idi?
  63. Gears in the rear
  64. Turbo question
  65. Hydrogen question
  66. Rustoleum Paint Job
  67. Hard start 6.9
  68. Vacuum line on heater box
  69. Cruise control issue
  70. Speedometer problem
  71. Retired Ambulance Stopping Distance Problem
  72. OD light blinking
  73. coolant questions
  74. 7.3 idi turbo question
  75. 1984 F250 7.3l non turbo..1st time buyer
  76. ip?
  77. 7.3L IDI Glow Plug Relay System Testing Procedure
  78. 7.3L IDI No Start Glow Plug Relay Clicking
  79. engine oil dipstick
  80. brake problem
  81. Under bed turbo
  82. turbo on a 93 non-turbo problems
  83. detroit locker ?
  84. 92 f250 2wd 7.3 idi
  85. Another starting issue
  86. what can i do?
  87. 88 c6 dipstick question
  88. Hard start warm or cold??
  89. 88 f250 hard to turn ignition when cold
  90. 6.9L IDI Tach
  91. 7.3 idi coolant filter install
  92. 99-06 cab on 1990 frame
  93. first real cold start ?
  94. Thinkin about buying an IDI
  95. 94f250 7.3idi axle swap ?
  96. 1994 idi turbo exhaust
  97. adjusted fuel screw ???
  98. Fuel adjustment
  99. Fabbing a turbo
  100. 1985 ford F 250 $x4 desiel
  101. Battery light. New alternator 12v
  102. Park Brake
  103. More air
  104. How to make biodiesel
  105. aftermarket guages ???????????
  106. Source for 7.3 IP
  107. 1986 ford f250 6.9 diesel cranks but won't start
  108. 94 7.3 idi turbo problems ??????
  109. When buying an IDI (Please read)
  110. 93 F250 7.3 Good Buy?
  111. 89 7.3 idi glow plug replacement
  112. high rev-no power when turbo psi rises
  113. Engine Grounds
  114. Fuel Pump in frame rail
  115. ZF-5 Swap Noise
  116. Turbo shopping list
  117. powerstroke to idi conversion
  118. LED light problem 1995 F250
  119. my 89 ford with 7.3 idi wont start
  120. Owners Manual for '89 f250
  121. Hydraulic Clutch Line
  122. 87 f250 search
  123. Couple quick questions
  124. 86 ford f250 6.9 diesel cranks but won't start
  125. Injection pump timing
  126. 88 ford 7.3 IP troubles
  127. Upgrades
  128. 7.3 shut off problems
  129. Help
  130. bad day? Injector problems
  131. IP not filling with fuel after pump adjustment
  132. injector fuel caps
  133. Leaking IP question
  134. Transmission
  135. 7.3idi glow plugs are burning wires
  136. tcm fuse keeps blowing
  137. 94 idi injection pump problem
  138. new diesel owner :))))
  139. 6.9 to 7.3 I.D.I swap
  140. 6.9 to 7.3 I.D.I swap
  141. Parts
  142. Gear Shift light
  143. Transmission Swap
  144. 94 7.3 Idi f250 pulls to the right
  145. coolant
  146. hard cold start on 7.3 idi
  147. Possible leak from IP
  148. 6.9 glow plugs
  149. '90 7.3 IDI glow plug problems
  150. 85 6.9 any advice
  151. new to diesels and about to purchase an 89 need advice
  152. 7.3 injectors/electric problems
  153. 7.3 non turbo wiring
  154. transmission shifting
  155. 7.3 electric problems
  156. 1986 f250 6.9 diesel engine bogging down
  157. 1986 f250 2wd to 4x4 swap
  158. Opinion's 7.3 Needs what? if anything?
  159. Fuel question
  160. Exhaust question
  161. strait axle swap on a 94 f 250
  162. got a overheating problem...
  163. F350 heater blows cold air
  164. alternater volts please help
  165. OFFTOPIC BATTERY CHARGER HELP!!!!
  166. best mpg's that y'all are getting
  167. SHOCKWAREHOUSE SUCK'S
  168. 90 7.3 injector pump
  169. 6.9 rebuild thoughts
  170. 85 f250 6.9 valve covers?
  171. 1989 f350 7.3l turbo problems!!??
  172. mystery part
  173. Puffs of smoke
  174. Puffs of smoke
  175. 7.3 IDI - fuel sys replaced, still problems
  176. 85 f250 6.9 Rear end problems
  177. Does a 1989 7.3 idi need back pressure ?
  178. my truck bucks
  179. Body swap
  180. My 88 F-250 Build and Pics
  181. 7.3 injectors
  182. 92 7.3
  183. Won't Start???
  184. Timing
  185. 7.3 IDI fuel problems.
  186. 1999 7.1 super duty transmission
  187. 1992 7.3
  188. 90 7.3 glow plug system
  189. Cruise Control
  190. 1992 7.3
  191. no oil pressure!!!
  192. Rear brakes
  193. looking at a trade gas for diesel help me pleaase
  194. What things should be routine maintenance that most will not think about?
  195. 1993 Owners Manual
  196. 93 F350 7.3 non turbo glow plug wiring diagram
  197. How to get the best sound out of an idi?
  198. major fuel leak!!!
  199. 88 f250 7.3 idi wont stay running!! White smoke
  200. 88 350 brake lights
  201. Coolant questions
  202. Adjusting injection pump issue!
  203. 88 7.3 non tbo mods
  204. 92 f250 4x4 brakes
  205. White smoke/ coolant loss problems
  206. help!
  207. 1990 7.3l IDI long cranking
  208. 1994 7.3L IDI turbo
  209. 1993 7.3L turbo starting problems
  210. rip off or not?
  211. Lookin to buy a 94 7.3 with a turbo
  212. A/C question
  213. my 6.9 needs to breath!!
  214. 91 f350 value
  215. 1987 6.9 california truck w/ factory ats turbo
  216. 84 6.9 will not crank with key
  217. 91 with rearend change, now speedometer is off.
  218. 7.3 Head gasket prep
  219. Serp belt alternator ignition bell
  220. 6.9 or 7.3 Swap?
  221. lack/loss of power, Help please
  222. 6.9 idi won't fire
  223. 7.3 IDI Headers
  224. Clutch question????
  225. GP controller
  226. Timing adjustment problem?
  227. 85 6.9 low oil pressure at idle
  228. '89 F-250 7.3 w/turbo came with the camper
  229. no wts light looked at controller n rigged up white wire not wts plug wire
  230. A radiator Question
  231. Injection Pump
  232. Advice on Buying a 84' F250 4x4
  233. Transmission question
  234. What is this gob of wires?!
  235. finding a good rebuilt injection pump
  236. giving a second chance to a forgotten old 7.3
  237. Exhaust system
  238. Holset HX55
  239. 7.3l idi hard to start
  240. CDR Valve on a 91 7.3 IDI N/A
  241. New guy on the block!
  242. 4Spd to zf5 on a 6.9 with hydraulic clutch?
  243. New owner 1986 f250 6.9 M/T
  244. E4od Transmission Fitment
  245. 6.9 strange fuel leak
  246. kornkutter
  247. Transmission problems
  248. 6.9 Draw, Searched and Nothing
  249. Should I buy a 1985 f250 6.9
  250. 5 speed manual tough to get into reverse.
